My machine stopped and made a constant beeping while the 3rd, 5th, 7th & 8th lights across the top remained on. What does this mean????
    President:
  • 1,554 Answers
It sounds like this is a Fisher and Paykel-made top load washing machine and you are referring to the Wash Progress LEDs. The flashing of the 3rd, 5th, 7th and 8th LEDs from left to right indicates fault code 43 and it means the Motor Controller Module has detected that the out of balance switch is permanently tripped. The out of balance switch lever may have been stuck in the open position or the harness connecting it and the Motor Controller Module is disconnected.
Move the basket assembly as far as it can go towards the right hand rear corner of the cabinet several times to possibly lodge the lever back into close position. Raise the top cover then locate the out of balance switch at the right hand corner of the cabinet then make sure the lever is hanging freely. Disconnect the out of balance switch wire harness, if the lever is properly hanging but the same LEDs are still flashing (Fault Code 43), then join the terminals together to bypass the switch.
Reconnect power then start the machine. Replace the out of balance (OOB) switch if the machine works fine with the switch bypassed. If not, check the continuity of the OOB switch wire harness and make sure it is snugly connected to the Motor Controller Module. The problem is in the Motor Controller Module if the wire harness is intact and snugly connected but the machine still doesn't work even with the OOB swicth bypassed. Replace the Motor Controller Module if that is the case.
Posted on Mar 23, 2011
  • Col Hickman
    Col Hickman Nov 13, 2011
    thank you Jahn 27...we did what you said & it fixed it..it was the out of balance switch being out of position....brilliant!
    (we are pensioners & would have had to save up for a new washer if it didn't work)
    from Norma
Fisher and paykel mw511 3rd, 5th, 7th and 8th lights on and beeping
this is a faulty out of balance switch which is located under the main computer module once replace sgould be ll good
Feb 16, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
Hi hav the Fisher & Pakyll Excellence top loader 7.5kg. It starts and stops on each cycle as if it hasn't enough power to get going. It beeps and lights up the 3rd, 5th, 7th and 8th lights across...
Hi - open the lid - poke your hand under the right corner - locate the lever hanging down & wiggle gently back/forth - this may release the out of balance switch - try it out.
Otherwise you need to remove the 2 screws on the back top corners - disconnect the power & cables under the display panels to remove the switch located on the right side with 2 wires attached to it - usually wh & yellow.
this is whats causing the machine to behave as you described...
Have a nice weekend..
Jul 01, 2011 | Fisher and Paykel (IWL12)
Machine will fill with water,will not spin to wash just beeps
Hi just read your posting.Now when the machine beeps an error code will appear.This will be in your LCD display or in a series of lights being lit.Now the lights that are lit when the machine is beeping will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 2nd and 5th or the 3rd and 7th ---etc---? Please reply reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel IWL12 Top Load Washer
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
I have a F&P Smartdrive excellence 7.5kg when turned on the water stops and starts then the machine stops and continuously beeps. the lights that stay on are the 3rd, 5th, 7th and 8th on the wash...
The machine has diagnosed that the 'out of balance' switch needs to be checked...It may be wiring, but most likely the oob switch has failed or the connections have become 'dry'..
The oob switch is situated under the motor controller module.
A very simple job for a tech.
Good luck....Nomess
Aug 03, 2010 | Washing Machines
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Jul 27, 2010 | Fisher and Paykel Washing Machines
My washer stops when it is in the draining proses almost when it has draining all water and it wont continue
Hi just read your posting.Now when the machine stops does, it beep and show a series of lights.If it does show lights that are lit then they will be in a row of 8 lights.Starting from left to right which ones are on?Is it the 2nd and 4th or the 5th and 7th ---etc---?Please reply with additional information and I can help you rectify this problem.
Jul 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
