Question about Garden
Paint will not come out nozzle,just blows bubbles in cup.parts manual please.
  • 4 Answers
SOURCE: My iwata hpc is pushing air back through the paint cup
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Posted on Jul 30, 2009
  • 14 Answers
SOURCE: blowing paint out trough cup
It is clogged and needs to be disassembled and cleaned with MEK. methyl ethel ketone
Posted on Aug 02, 2009
garyatwell
  • 72 Answers
SOURCE: The siphon cup is bubbling and pressurizing when I
Check the nozzle and housing for old paint build up
Posted on Nov 07, 2009
  • 188 Answers
SOURCE: IM GETTING NO FUEL COMING OUT OF THE NOZZLE. WHEN
Nozzel can have a blockagr (clean or replace). Dirty filters (replace) Gap too wide between the rotor and compressor ring, or rotor can be worn or broken. Tha manufacturer has a technical service manual on there site the would help you greatly. You can go to www.desatech.com. I hope this helps!
Posted on Jan 28, 2010
SOURCE: My airbrush is bubbling out of the paint cup and
Check your air brush manual .. your compressor nay be set to an air pressure that's too high.
Posted on Jan 17, 2011
I'm having a problem with my finish line flg 3.. I'm getting air bubbles blowing back up into the cup of my gun causing the paint to spit out when I try to spray.. Is there any reason this would be...
Make sure that the vents on the gun are clean and if the problem is still present then you have a problem with wear on the bushing or the needles. Air is blowing back into the cup before the needle is opening enough. So this could be a pressure, timing or wear issue.
Nov 25, 2013 | Air Tools & Compressors
Master g22 air paint
Do you have a water separator attached?
Jul 11, 2013 | Crafts & Hobbies
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
IM GETTING NO FUEL COMING OUT OF THE NOZZLE. WHEN I PUT THE FUEL LINE IN A CUP ITS BLOWING BUBBLES INSTEAD OF PULLIG FUEL
Jan 23, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Blowing paint out trough cup
Aug 01, 2009 | Air Tools & Compressors
Jun 16, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
