Question about Pool & Spa
How do i get all the air out of the leaf basket on a sf20110
  • 1,383 Answers
There should be no air this is a positive pressure pump. " the pool water is higher than the pump.. so if i would guess , just loosen the lid, it will self prime, or your impeller may have trash in it and it's not able to move the water good enough to remove the air.. try back flushing the pump with the garden hose..
Posted on May 27, 2011
I need a repair kit for a sandfliter modle number 20110 do you have this
Sir,
This is an easy fix. You will have to take the filter assembly apart. Go to your local pool shop ,ask for Silica filter pool sand. You will notice a gasket on the top. Be gentle with that. Mark the orientation of the pump head. Take a picture or two. Eye ball the level before you start to clean it. Magic mark outside.
Get a clean wheel barrel or a tub. Flush the sand and grit from the vessel. Be careful of the tubes on the inside. You can wash the sand clean from all the debris or replace it. I would replace it. I believe 2 bags should do it. Cheap. Have done a few. Worth the effort. You will be happy you did. The whole process takes about 3 hours including the purchase of the product. Reseal all your connections with new pipe sealant or tape.
The largest failure when doing this is air infiltration by suction. Tighten enough but not too much and mark all your plumbing with matched coding tape until done,clearly identified, if your knew at this project. There are a rainbow of colors to choose from and the alphabet, I hope your days are wet and relaxing. Do not let the word kit stop you. All that is in the filter is SILICA sand. Make sure you get that for replacement. They have figured for you. Good Day.
Here is the online Intek store link should you need more than just sand,
Search results for SF20110 sand filter pump
16 in Krystal Clear Sand Filter Pump GFCI
In conclusion, I highly suggest you watch this video. It is Intek supported. I agree with its message. Intex 2650 gal hr Sand Filter Pump Setup Instructions .
Jun 20, 2014 | Computers & Internet
Index sand filter pump SF 20110 will not blow water into pool
I don't know how much time you are giving it, but sometimes when I start my pump, it'll take 20 minutes or so for it to start a full stream of water. Also, make sure the valves are turned to the unlock position on the incoming and outgoing hoses.
Jun 03, 2014 | INTEX Sand Filter Pump
I have a sf20110 and it resets itself
Sounds like battery is weak. replace the battery, and check. Gopakumar Gopalan Google
Jun 02, 2014 | Cell Phones
Will a 240 hayward sand filter with the SPX0710X32 valve, allow
If they are to much for the pump basket you can try filter by-pass. Another thing could be a tool called a leaf master that hooks on your garden hose and sweeps any and all light stuff from pool and collects in a bag big enough to hold it all in one sitting.
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
Pump shuts off after a minute and isn't filtering water
there is something blocking the passage of the water, go through and check all the passages for any kind of blockage
May 26, 2010 | Intex 2100 Gallons Hours Sand Filter Pump...
We just bought a Hayward Leaf Canister, Model #W560 to catch leaves in our inground pool, but instructions were not included. does anyone know how to get into the leaf basket? We were able to unscrew the...
unscrew the lock ring and pull, the lid should come off with the lock ring. If not, line up the notches in the ring with the slots on the lid and pull. You should then be able to access the basket to clean it.
Apr 06, 2010 | Hayward Navigator Pool Cleaner
Pool pump won't prime
check for air leaks, cover o-ring is common culprit. anything in front of pump can cause this.
Jan 17, 2009 | Pentair 1.0 Hp Whisperflo Pump
Spa - Low water flow
Split the pump. if you don't have a leaf/pump basket then your pump inpeller is propably dirty, you'll need a very thin screwdriver to clean the holes inside the impeller
Jan 02, 2009 | Pool & Spa
Condensation build-up in the dryer drum, clothes remain very damp
You deffinately have some sort of blockage in your exhaust vent, most likely in the wall. Check the outside vent on the outside of the house. The air should be blowing pretty hard. hope this helps. Dave www.washermd.com
Dec 17, 2008 | GE Profile DPSB619ED Electric Dryer
Pool & Spa Logo
67 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
