Question about TruTech Televison & Video
I turn the tv on it comes on for about 3 sec then shuts down
  • 822 Answers
New caps needed on power supply...........
cheers
Posted on Mar 22, 2011
Samsung TV no sound no picture backlight on and off
Check voltage at the power board. After 120 volts enter the TV, there is fuse then a small high voltage transformer, then a 100 uf rated at 450 volts capacitor. There should be 390 volts DC at the capacitor. Without this 390 volts the TV will shut down.
Dec 28, 2017 | Samsung Televison & Video
I have a Panasonic PT-47WX42 .. porew light flashes 3 times the stops,, then repeats..if I unplug the power cord then turn on the tv. it warmsup the picture comes on for maybe 3 sec then hear a click just...
The 3 blinks is indicating the set has shut down due to the convergence circuits. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Jul 28, 2011 | Panasonic PT-47WX42 47" Rear Projection...
It doesn't want to shut off and we have no heat?
when you say it doesnt want to shut off i'm guessing you mean the fan. the fans run on a timer when the thermostat calls for heat it will come on 90-120 sec.later. turn your t stat down below room temp and it will shut off in 30-60 sec.your ignitor is most likly bad. turn your t stat back up and look at it. it should glow. furnace will try to light 3 times,you may hear the gas flow for 3 sec.during this cycle. if no glow good chance that is your problem and you will need to replace it.be carefull it is very brittle and breaks easy if tapped. be sure to turn the t stat down again or the fan will start running again.
Jan 26, 2011 | Coleman Propane Forced Air Heater...
Hi, I replace the lamp in my Somy KF-42E200A and when I power on my TV it come up for about 3 sec and the TV shut down and power light come red. Any ideas?
Dude, you have the same problem I have EXACTLY....except my tv runs for 2 minutes before shutting down.
If I solve this (when) I will be in touch.
Nov 03, 2010 | Sony KF42E200 TV
When i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
Hi, Does the set come on for about 30 sec.? I had a 50V715 hitachi, it came on for about 30 sec. then shut down and then it would repeat the process. After about 3 wks and alot of other pain, it turned out to be the lamp was weak. Replaced the lamp and all is great! So... it could be your lamp is going bad. Hope this is helpful.
Nov 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi projection tv will only turn on periodically. I power the tv up and sometimes it turns right on and other times it seems to power up but then front 3 lights on the front start blinking and the tv...
I don't know what model you have but ... the 50v715 I have did the same thing. Would come up for about 3 to 30 sec's (picture and sound) then shut down and do again. It was the BULB going out. You probably just need to replace your bulb. Check your manual on how to change it out. Make sure you buy an original Hitachi replacement I think there made by phillips. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
