Question about Canon PIXMA MP240 All-In-One InkJet Printer
It won't feed paper - Canon PIXMA MP240 All-In-One InkJet Printer
    Novelist:
  • 137 Answers
If you haven't had a paper jam, recently (you do not mention a jam in your question) then consider this and try this:
Got Kids?  Have You Had Little Visitors Lately?
1.  Turn Off The Power
2.  Unplug The Printer
3.  Gently, tilt the printer so the paper feed try is facing the floor and give a gentle shake.  I have found: coins, paper clips, thumb tacks, Swiss cheese....
This link will bring you to The PIXMA Clear Foreign Objects Fom Rear of Printer
This link will bring you to the PIXMA Cleaning Rollers Windows
This link will bring you to the PIXMA  Load Paper Properly page.
This Link to Straighten Paper
If this doesn't work for you, try taking following these, generic, paper jam clearing steps in this video
Posted on Mar 22, 2011
  • Canon Master
  • 3,866 Answers
Hello, Welcome to Fixya.com
The paper feeder sensor in the APF is what might be causing your issue.
1. Check for any jammed paper in any part of the printer.
2. A jammed piece of paper can cause the paper not to feed.
If that is not the case you might need to have this looked at locally.
Regards
rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark X85 won't feed paper. When trying to
    There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
    1. Remove the sheets of paper from the feeder.
    2. Grab a flashlight and look inside for any debris.
    3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
    6. If cartridge area is clear, close the cover.
    7. Unplug and re-plug the printer into the power outlet to reset it.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
    ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
    7. Close the printer cover and check for any errors.
    8. If no error appears, reinsert the other cartridge. Close the printer cover.
    9. Replace whichever cartridge is causing the error to appear with a new cartridge.
    Posted on Aug 03, 2011
    Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
    mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
    Aug 22, 2012 | Casio HR-100TMPlus Calculator
    Re; fr3950EP machine, I moved the paper sideways 10mm, light gone out and machine won't start again, display panel just says check paper feed area
    Pls, I have risograph FR3950EP
    I need the full drum unit, computer interface card, master and inks of different colours. Kindly help me out. I am in Nigeria.email: engrmoob@yahoo.co.uk
    Nov 26, 2011 | Riso RZ220 Duplicator
    My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
    When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
    Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
    Try cleaning the rollers with methylated spirits.
    Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
    The machine won't print. It won't feed paper, The
    Your machine needs to be serviced.
    replace the cartridge with the original one.
    it can not print if one cartridge is missing or not original.
    Jul 12, 2011 | Canon Office Equipment & Supplies
    Green light for paper feed isn't on and paper won't feed
    paper start sensor is not functioning properly. clean it or replace it.
    Jun 16, 2011 | Canon imageRUNNER 2200
    Paper won't feed properly and jams. the paper starts to feed then twists and jams.
    There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
    Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
    Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
    May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
    Print head alignment +won't feed paper
    Best solution is to clean the head with it in place,here's
    the manual for your printer
    Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
    Canon PIXMA MP240 All-In-One InkJet Printer Logo
    239 people viewed this question
    old marine
    old marine
