Question about HP LaserJet 1320 Printer
I have a iMac G5 with 10.4.1. I try to print coupons on my hp laserjet 1320 and they stay in the que. Word docs print fine but any time i try to print any kind of coupon from any site, it messes up the print and other docs don't print, it just makes a long que. Help!
  • HP Master
  • 1,915 Answers
If you are printing PDF coupons, that is probably the case, you need to upgrade the memory on the printer if you want faster printing on those types of documents.
Posted on Mar 23, 2011
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
HP Laserjet 1320. Will not stop printing and not showing up in the Que. I have unplugged overnight, I have cancelled all jobs in the Que and will not stop printing. How do I cancel the job
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click START
Click RUN
Type CMD ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 07, 2010 | HP LaserJet 1320 Printer
My hplaserjet 1320 prints multiple copies when printing Excel Doc
The best thing to do as a starter is:
1. uninstall the print driver THEN
2. download the latest version from the manufacturer and install it
This rules out the driver as the cause of the problem
1. Go to printers
2. Right Click on the Printer HP Laserjet 1320
3. Click on Printing Preferences
4. Click on Advanced
5. Double Click (to open) on Paper Output
6. Ensure that COPY COUNT is set to "1"
If it is already set to one, trick the system a little:
1. set it to 2 and save that setting
2. then go back in and set it to 1
Good luck
Mar 15, 2010 | HP LaserJet 1320 Printer
Hp Laserjet 1320 toner rubs off page
when the toner rubs off means it wasnt fused which means you need to replace the fuser
Feb 27, 2009 | HP LaserJet 1320 Printer
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
Problem HP 1320 not responding
Try changing to a new USB cable
Jan 31, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 - Acrobat problem in XP
please reinstall the printer driver and also reinstall your window
Sep 19, 2007 | HP LaserJet 1320 Printer
Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Feb 14, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
