Question about Kenmore Dryers
I hear rattling when the dryer runs, even when it's empty. I'm pretty sure there's loose change stuck under the baffle (fin inside the dryer). How do I get inside the dryer to remove the baffle?
  • m6soto Mar 23, 2011
    Fantastic! I had been hunting around the web for info on how to get inside...That first vid link did just perfect. Thanks kdrake84!
    Guru:
  • 262 Answers
You will need to decide which video fits your machine appearance.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
How to change the baffles click on the link http://www.youtube.com/watch?v=FXcveP1_aXU
If this has helped you please consider giving us a 4 thumbs up on our rating.
Thanks in Advance and Thank You for using Fixya!
Posted on Mar 22, 2011
  • Keith Drake
    Keith Drake Mar 23, 2011
    That is great! That is why we are here. We like helping people.
    Keith
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
The wedges inside dryer, can they be removed and put back? I hear lots of change and things inside of them.
The baffles yes take off the top loosen the screws don't take them all way out rotate and shake loose baffle repeat for others
Sep 22, 2014 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Sdg109wf when running it like rattling sound coming out. what do i\I have to do?
You may have to find a way to identify the location of the sound; type of sound..metal on metal, like something is loose?
The only thing I know that rattles in a dryer is if something got into the baffles/the wings on the inside of the drum.
If this is the case you have to open the top of the drum and unscrew the one baffle that that has something loose in it.
Oct 18, 2013 | Dryers
Broke fins/tumblers
This is an easy fix. You need to pop the top of the dryer up to do so. Depending on the model you may have to take the front off (older models), or just locate the clips located on the left and right side under the lid, and with a flat head screw driver push them in and lift up. (newer models). After you have the top up, located the baffle thats broken and install. Keep in mind that if the baffle is loose its more than like the hole where the screw goes is stripped and the whole baffle should be changed.
May 29, 2012 | Maytag MDE5500AYW Electric Dryer
Rattle noice engine around the calelitic converter. rattle noice when starting car up when cold. poor gas mileage.
Sounds like you may have a exhaust loose or either the cat converter is stopping up. Some of these have baffles inside which will break loose and cause a rattling noise. When the engine is cold, start the vehicle and crawl under and hold the converter with your hand and even the exhaust to see if any pressure will stop the or alter the noise. Careful it don't take long for the exhaust to heat up. If these baffles are broke inside, it can cause the converter to become stopped up and rattle, this will also give an engine false info when it comes to the fuel and air ratio mixture. Not going to far into it, so i don't confuse you. Good Luck
Mar 04, 2011 | 2008 Subaru Impreza
The tumbler makes a terrible noise - I'm sure it's just a coin or a screw rattling around in there. I can't figure out how to get inside to look around the tumbler to see what it may be. And once...
Open the door and look inside - yes, you can see everything inside the drum. Sometimes buttons, especially the metal ones on denim pants, can make a pretty good racket.
If you don't find any foreign objects inside the drum, and the dryer makes noise even when it's empty, it may be time to change the drum rollers or the belt tensioner pulley. It's also remotely possible that there's something batting about in the blower housing, but if that is the case, it would probably be a screw or something broken off of the ductwork, or the blower itself is loose on the shaft. Post back if you need instructions for checking the mechanism underneath the drum.
Nov 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
Loose and broken baffle
d
Take off 4 door screws 2 right 2 left remove door pull front forward them two screws 5/16 in front with two brackets that hold top down. thats it just rotate drum and tighten or replace fin . ten minutes tops is all it takes.
my fin broke the screw holes so i will try longer screws if not i will leave off and run with two.
Mar 07, 2009 | Maytag MDE7600AY Electric Dryer
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
