Question about IBM ThinkPad T30 2366 Notebook
Ibm t30 keyboard stuck in odd mode
This makes sense but none of the function keys have the euro symbol
I tried pressing fn & each of the function keys and doesn't work
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    What country to you reside in?
    Worldvet
    Genius:
  • 2,028 Answers
First, if there is no Euro symbol then this isn't a European keyboard, or it was made before the Euro was introduced, which I believe is the issue in this case, and there's nothing that can be done to get the Euro into the system. As far as the function key is concerned, you may need to do a bios flash or update in order to restore the function key features. Do the flash/update and get back to me.
Posted on Aug 05, 2008
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
IBM T30 wireless and graphis driver
it might be that your wireless is not activated or disabled. look for a key on your keyboard which has a wireless picture on it,then press that key with the Fn (function) key at the same time when you're on the desktop. or if it's still doesn't work,the network you try to connect is not available
for the video driver,you can download it here
http://support.lenovo.com/en_US/?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=10&familyind=99273&machineind=99914&modelind=103950&partnumberind=0&subcategoryind=0&doctypeind=9&doccategoryind=0&operatingsystemind=53385&validate=true
Aug 26, 2012 | IBM ThinkPad T30 2366 Notebook
I want to know how to use the function button
The function button, or FN button, is used just like the shift key or ctrl key. Hold the FN button down and press the key with the pre programmed function you desire to use. For instance, on an HP 1245 the function or short cut key to put the computer in sleep mode is FN+F5. The Keys with functions have that feature indicated by a symbol for the function in a squared circle. Most of these are your F keys at the very top row of the keyboard. Some are on the number pad keys.
Oct 27, 2011 | IBM ThinkPad R31 2656 Notebook
On my Benq keyboard Model A800 I have the Euro symbol written on key No. 5, but I do not know how to print this Euros symbol using this No.5 key.
Press the 'FN' key (sometimes called a 'function key', and, while holding it down, press the '5' key.
This will put the symbol on screen for you to print out.
Jan 31, 2011 | Computers & Internet
Simply change my keyboard from typing numbers instead of letters..I.e. I'm trying to type yonkers and it gives me y6...I know it is a simple F6 or F2 function but I forget. Its been a while since I u
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
Apr 26, 2009 | IBM ThinkPad T30 2366 Notebook
Laptop keyboard issues
Is this a laptop? Some laptops will allow you to use these keys as the number pad/arrow pad as well in a certain mode. You will likely be able to turn off with a combination of the FN key plus one of keys F1-F12 (the function key will perform the action shown as a symbol on these keys).
If none of the symbols seems to indicate this mode. Try each combination and test to see which combination sets your keyboard mode back to normal.
Jan 05, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
You've activated Euro mode. This is toggled by pressing holding the Fn key plus an Fkey that has an icon in the same color as the lettering on the Fn key that looks like the Euro symbol. Press the Fn key plus the Euro key to toggle out of Euro mode.
Regards,
Worldvet
Aug 03, 2008 | IBM ThinkPad T30 2366 Notebook
Thinkpad t30
There is a num lock key. Press Fn Num Lock (I believe it is the scroll lock key on this particular keyboard).
Jul 02, 2008 | IBM ThinkPad T30 2366 Notebook
Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
Apr 04, 2008 | Balance CN6555 Notebook
IBM ThinkPad T30 2366 Notebook Logo
183 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
