Question about Canon BubbleJet i560 InkJet Printer
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck. NowWhat????
  • 41 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Posted on Mar 22, 2011
Flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
May 10, 2010 | Canon BubbleJet i560 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My canon i 560 does not respond at all. when i turn it on the light flashes 5 times orange and once green. and it repeats this
    Generally speaking the Orange light flashes 5 times to indicate a print head error.
    Did you recently remove and install the printhead? It may just need to be reseated. The printer may also need a service repair.
    Don
    Dec 12, 2009 | Canon BubbleJet i560 InkJet Printer
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
    Why flash by 5 times the orange led?
    Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
    3. Release RESUME
    Good Luck, I hope this helps?!
    Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
    IP1800 PIXMA printer will not print.
    If consumables are all replenished, your printer should work properly.
    Apr 15, 2009 | Canon PIXMA iP1800 Printer
    Orange light blinks 7 times then green light once and repeats,
    It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
    YBC (/\)
    Oct 07, 2008 | Canon i950 InkJet Photo Printer
    Canon i560
    may be ink level is too low,check it first,make sure delete the all pending documents
    regrads
    prasanna
    Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
    Canon BubbleJet i560 InkJet Printer Logo
    446 people viewed this question
    old marine
    old marine
