Question about Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
My MW24FN1 (-R), all of a sudden turns off when I turn it on. Yesterday, I turned it on, heard a single word of a program voice and it turned off. Turned it back on, and instantly it turns off....over and over again, no matter if I use the remote or the power button on the TV.
  • 1 more comment
  • Corky Akins Mar 23, 2011
    Is that the only feedback I am going to get on this issue? Does anyone else agree with this diagnosis?
    Is this something a lay person can do? Can't say I have ever worked on electronic stuff other than ram changes on a computer, but if is just something with tins that plug in, I may give it a shot!
  • Corky Akins Mar 24, 2011
    Thank you so much for an excellent response to my issue!
  • Toshiba Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 23, 2011
  • Walesarumi
    Walesarumi Mar 23, 2011
    it has nothing to do with plugging in anything. It has to do with soldering things on the power supply board. Capacitors and other components on the power supply board are soldered. If you are not sure, then maybe you should give this task to someone who can. But can can still give it a shot. Unscrew the TV back cover and check the power supply board. If you cannot do anything on it, you can leave it for someone who can help you out. Good luck again......
  • 4,472 Answers
This sounds like an issue with the power supply. Could be the over voltage protection shutting it off right away. Given the age and size of this television you may want to consider replacing it.
Thank you,
Lee
Posted on Mar 22, 2011
Why doent my gps speak s
The things you'd want to check first are:
1. the volume of your speaker is not turned off ...
2. your GPS (navigation) software supports voice navigation - directions /commands ...
3. you have (installed & selected) a navigation voice (e.g. standard or computer voice)
4. you have done a "reboot" ... or "hard reset" ... to start the software up again.
If all of these are OK ... and you previously had heard navigation voice on your GPS ... but suddenly, there's no more navigation voice, then it is possible that the navigation software (voice portion) got corrupted. If that's the case, you would want to try to restore your software from backup (using HOME), or download a copy of the navigation software from TomTom.com (for your device type/class) and install it.
Dec 28, 2013 | GPS
KEY FOB
Hi there:
From Owners Manual...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 02, 2012 | 2008 Dodge Ram 1500 2WD
P5qc power failure
What you should try always, is to reset the BIOS by clearing the CMOS. On some motherboards, you can use jumpers instead of unplugging the power and taking the battery out. If it still turns on without you pressing the power button, you should look into your BIOS and see if you need to change some settings about A/C Power Loss in the Power section.
Mar 07, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
No voice
hook your gps up to computer and turn gps on, load garmin program and download free voice to it from internet
Jul 24, 2009 | Garmin nuvi 750 GPS Receiver
Programming instructions for 2006 Mitsubishi raider remote
Note when entering program mode using that fob, all other programmed transmitters will be erased and you will have to reprogram them for your vehicle. Use the following procedure to program additional key fobs if the vehicle is not equipped with Sentry Key:
1. Enter your vehicle and close all doors.
2. Fasten yo belt to cancel any chiming that may confuse you
3. Place the key into the ignition turn to on pos. do not start
4. Press and hold the UNLOCK button on the key fob.
5. After holding the UNLOCK button for four seconds, also press the PANIC button within 6 seconds.
6 When a single chime is heard release both buttons. The chime is an indication that you have successfully entered program mode. All transmitters that are to be programmed must be done so within 60 seconds of when the chime was heard.
7. Using the fob to be programmed, press and hold both the LOCK and UNLOCK buttons, simultaneously for 2 seconds and them release.
8. Press and release the UNLOCK button a single chime will be heard,
9 Repeat steps 7 and 8 to program up to six additional transmitters.
10. Turn the ignition to the OFF position.
11. Your vehicle will remain in program mode up to 60 seconds from when the original chime was heard. After 60 Seconds, all programmed transmitters function normally.
Apr 21, 2009 | Mitsubishi Raider Cars & Trucks
I have a cordless phone Philips CD 440. I cannot turn off the red flashing light after having heard and erased a voice mail. I need step bystep instructions on how to turn off the voice mail indicator...
It is the responsibility of the telephone company to shut off the voice mail signal. They have been notified and will fix the problem.
Thanks.
Aug 29, 2008 | Lands Phones
No voice navigation..
all of a sudden we have no voice on the jack or on speaker, have tried to turn down setting and turn them up again...no luck no voice...
Aug 15, 2008 | Garmin Nuvi 660 GPS Receiver
Toshiba MW24FN1 24 in. TV/VCR/DVD Combo Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
