Question about Danby DWM5500 Front Load Washer
My Danby Front load washer will not spin or turn on wash cycle or on final spin. It will fill and pump water out but will not turn.
  • herongraphic Mar 22, 2011
    I checked the belt and seems to be fine. I can turn pulley and the drum will move.
    My belt seems to be ok. Drum can turn when I spin the pulley.
  • 1,998 Answers
If its not turning most likely you would be having a motor issue remove the top cover by the small screws located on the back of the machine and slide the top panel back.have the unit off and try spining the unit you may notice there might be a broken belt that is on the rear pulley or that the belt is not on the pulley if you do not see a belt most likely it is down the bottom of the machine if the belt is still present on the pulley try spining the rear pulley which is seated with the drum if you are unable to then you would then have to check the motor or on some units there is a motor control board located down the bottom as well but check the belt first and then message me back as well as if you have any further questions . Thanks again for using fixya
Rick
p.s some one also posted If the "Spinning Off" button is pushed in you will get this problem on our link as well but most likely your belt has broken http://www.fixya.com/support/t1595399-danby_front_load_washer_will_not_spin once again any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations
Posted on Mar 22, 2011
  • Rick Ead
    Rick Ead Mar 23, 2011
    ok if the belt is good then you would check the motor and the motor control board These are both located down the bottom of the machine Thanks Rick
  • Rick Ead
    Rick Ead Mar 24, 2011
    awaiting your reply on how you made out with the motor and the motor control please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
    p.s i will be unavailable from tuesday the 29th -thursday 31st flying across the country
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Danby front load washer Will not spin motor runs
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Jan 25, 2009 | Danby DWM5500 Front Load Washer
Horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Dec 26, 2008 | Danby DWM5500W Front Load Washer
Getting nf code on final spin cycle
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Danby DWM5500 Front Load Washer Logo
73 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
