Question about Smoothfitness Exercise & Fitness
Hey guys, i got a 945st treadmill, belt tore and clogged up machine. cannot restart , fixed belt, what do i need to do to restart
    Guru:
  • 1,833 Answers
According to you your treadmill doesn't restart. Unplug your unit take the motor shroud off. there is a circuit board (Motor Control
Board) their should be L E D s on the board. Now plug your unit in and you will see these light up. There is a 3 amp fuse in the board to protect the board from damage. You can change the fuse to run the system. This may be the problem of a bad control panel. The control panel controls all the functions of the unit it accepts commands and executes them. Often times it would accept a command but not execute as a result of malfunctions on the control board. That's why it doesn't function. For the Best result you can try to replace or repair the control board which can be done by any service repair technician or contact the nearest dealer for a repair person. But check the electric outlet and the power unit of the Treadmill before.
Posted on Mar 23, 2011
How do i remove treadmill front roller
Hey, I really think you should have mentioned the brand of treadmill but however all the treadmill i encountered all function on the same principles... though some may seem more of a hassle to do they are all the same (correct me if i'm wrong)... So with that being said you would need to remove the motor housing cover by removing all the screws around the sides and front of the machine. By now you should have a clear view of the front roller, on one side you should the the belt driven pulley that is held on by the belt alone so removing that along with the bolt on the opposite side should do the trick.... lemme know if this helped
Jun 25, 2014 | Nordic Track NordicTrack Treadmill, A2550
Acd3 treadmill belt wont move
hi There.
A treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.
If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.
If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.
or read up some more at this link.
How to Fix Treadmill Belt That Won Move
or this one.
Acd3 treadmill belt wont move Google Search
Dec 16, 2017 | Exercise & Fitness
There is a knocking sound coming from bottom of machine when belt moves.
The treadclimber is a nonsense scam and they are the cheapest made product on the market. You are better off throwing that thing in the trash than paying to have it fixed.
Aug 06, 2017 | Bowflex Treadclimber
What's your problem?tread mill stop working belt stopped turning
Dear Sir:
Hello I hope you are o.k
After Reading your problem, I will help you please follow the next step:
Your problema is Electrical:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
If you have questions, email us at doc@treadmilldoctor.com
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if
equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix (that we don't recommend) try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact me with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel . Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or a console.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
I bought a Reebok V8.90 with iFit cards. My problem is that the workout will stop multiple times during the workout. Then I have to start over. It seems that each time I start over I can get a little...
Dear Sir:
I hope your are very well in union with your family.
I will help you inmediatel.
Please do the following:
1)
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker.
The amount of time required to shut down will progressively get shorter.
go for a cheap fix try lubricating the walking belt. The best fix is to replace the
2)
the deck for wear too. If you want to go for a cheap fix try lubricating the walking
3)
Solution: If you get an error code, contact us with the code and make and model and we will try to help
board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
case corrosion is causing.
Thank you in advance, sincerely. God bless you.
If you need further assistance,please contact us.
E.CUADRA
Sep 27, 2011 | Exercise & Fitness
Running belt has creased badly, will I need new belt ?
Wow, this is weird, I've just come back from the gym and the guys there were 'fixing' a crease on one side of the belt.
They had the belt off the treadmill, and put a wooden board on the inside, with some weight plates on them, a few wooden blocks on the inside, so the belt looked like it was the same height as when it is fitted and then a wooden board and weights on the top.
By the time I'd finished my session, they were refitting it and it looked good, you could still see a slight dent, but not a full crease.
Hope this helps you and good luck.
Jul 18, 2010 | Tunturi T30 Programmable Treadmill
THE BELT ON OUR MACHINE IS BROKEN CAN I BUY A REPLACEMENT AND HOW DO WE FIT THE NEW ONE ON ?
The treadbelt can be installed by removing the front roller, the drive belt, rear roller and screws in the siderail. You do not have to remove both sides, just lift the deck and slide new belt on. To save yourself some agravation, you may cut the old belt off.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly... 877-805-1030
Mar 15, 2010 | Reebok Rt1000 Treadmill Walking Belt
My machine turns on and then immediately shuts off
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck. Here are the most common symptoms and solutions:
  1. Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The amount of time required to shut down will progressively get shorter.
    Solution: The walking belt is worn. The incline test is the best test for it if you don’t have a way to take a DC amp draw. Put the treadmill at full incline and walk normally. If it takes longer to shut off or does not shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to go for a cheap fix (that we don’t recommend) try lubricating the walking belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
  2. Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required before it shuts down gets progressively shorter.
    Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect the deck for wear too. If you want to go for a cheap fix (that we don’t recommend) try lubricating the walking belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
  3. Symptom: The treadmill shuts down in an intermittent pattern…there is no rhyme or reason to when it will shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or reset it to restart the treadmill.
    Solution: If you get an error code, contact us info@fitnessgt.com with the code and make and model and we will try to help you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or some call it a console.
Feb 18, 2010 | Exercise & Fitness
Exercise & Fitness Logo
176 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
