Hotpoint Front loading Aquarius WF210 Where is filter to clean fluff etc. our machine leaks
    Brigadier General:
  • 6,277 Answers
Same again!
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf210 filter location?
Hi!
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
How do I find and clear the filter in Hotpoint Aquarius wf210?
pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Leaking washing machine
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 01, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Water still in drum after programs finished.
This is caused by the water level switch not working correctly. This is most commonly caused by the internal filter being blocked, you need to remove the filter and clean out all the buttons coins and lables ETC , see the note on how to do this from other user
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
