Question about Estate Dryers
My tension pulley has come off, i pulled the front cover off and looking at it i cant tell where it went
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
my tension pulley has come - smitty545_4.jpg Look at the last picture for Whirlpool dryers. It slips into slots in the bottom of the cabinet.
Kelly
Posted on Mar 22, 2011
I have a 1994 ford taurus SHO with 9 pullys including the crank shaft and noone can tell me where the tensioner pully would be or what it would look like.... it's a 3.2 liter v6. i've even went to ford can...
the pulley piece should look something like this:
it can be almost anywhere on the belt side of the front of the engine. if you have a long belt or many belts then there can also be more than one idler pulley (tensioner pulley)
Mar 31, 2011 | Ford Taurus Cars & Trucks
How do I tell if the timing belt is bad. I have the covers off. The crank timing mark is at TDC. the cam marks are also aligned When I first got the covers off the timing belt seemed loose and I could...
Timing belts are supposed to be replaced in intervals, on this vehicle every 60,000 miles. The timing belt may look good, but they mostly stretch over time. As for the looseness and becoming tight, its because there is different compression tension that pull either way. But to be loose to the point you can spin the tensioner pulley, replace everything (belt, tensioner, idler pulley, water pump)!!
Sep 27, 2010 | 1998 Mitsubishi Montero Sport
How do i release the tension belt ... cant seem to find bolt being referred to in other docs
Here's the procedure on how to release and replace the tension belt of your car.
Step 1
  • Open the hood on the Volvo S-60 and find the serpentine-belt routing diagram. The diagram should be attached to the top of the fan shroud that covers the radiator. If not, draw out the exact routing method of the serpentine belt around each pulley with a pen and a piece of paper.
  • Step 2 Locate the serpentine-belt tensioner that is in the very center of the engine. The tensioner will have a square bolt head in the center of the tensioner pulley.
  • Step 3 Slide the open end of the 5/8-wrench onto the square bolt head in the center of the belt-tensioner pulley. Turn the tensioner pulley counterclockwise and slide the serpentine belt off of the tensioner pulley.
  • Step 4 Remove the serpentine belt from the other pulleys and pull the belt out of the engine compartment.
  • Step 5 Slide the new serpentine belt into the engine compartment and around the crankshaft pulley.
  • Step 6 Route the new serpentine belt around each pulley. Turn the belt-tensioner pulley counterclockwise again and slide the serpentine belt around the tensioner pulley. Release the tensioner and it will tighten the belt around the pulleys. Look over the belt to ensure that it is inside of each pulley.
  • Step 7 Crank the S-60 and look over the serpentine belt with the motor running. Let the engine run for about one minute and shut the engine off. Close the hood.
  • Aug 12, 2010 | 2001 Volvo S60
    How do ifix my tension pulley for my water pump cant figure out the best way to take off the pulley
    1. Remove air cleaner assembly
    2. Remove water pump belt cover
    3. Remove water pump drive belt
    4. Replace tension pulley
    Feb 09, 2010 | 1997 Cadillac DeVille
    Need to replace serpentine belt on 2000 dodge caravan,,6 cyl,,air,,,, email cntrywv1@ayhoo.com
    OK, do you have a specific question? You'll need to jack up the front right tire and remove it. Pull the wheel well cover off to expose the belt. Use a vice-grip in the tensioner pulley (look for a 1.2 in square on the end of the pulley) to remove tension. Install as the sticker under the hood shows.
    Jan 24, 2010 | 2000 Dodge Grand Caravan
    Hi, could you please tell how to remove the bottom cover on a 1.6 vw bora......which is covering the bottom pulley for a timing belt change..... does the tensioner need to come off.....? and if so how do...
    the one on the engine ?? two bolts either side ,cant remember but yes you may have to remove the fan belt tensioner thinking about it ,quick tip ?? to undo the bottom crank pulley bolt ,use a knuckle bar on socket and jam the knuckle bar into suspension then crank with starter motor ,undoes them everytime it does.Then before you slacken anything to do with the timing ,bring it around to TDC no 1 and paint all the pulleys to the block with white paint ,except the water pump and idlers .
    Nov 10, 2009 | 2002 Volkswagen Golf
    I cant find the tension? I get it on the pulleys,
    The tension release pulley, located just below and in front of alternator, has a 1-2 slot in the center of pulley. Insert the 1-2 inch breaker bar in middle of tension pulley and pull up, tension will be released. I hope this helps. Don,t forget to rate my answer, thanks.
    Feb 27, 2009 | 2003 Chevrolet Silverado 2500HD
    Need the belt diagram for the water pump belt for a 95 Auroa
    42161874BELT, REPLACE
    1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
    2. Raise and support vehicle.
    3. Turn wheel to the extreme right and remove right side splash shield.
    4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
    5. Lower vehicle.
    6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
    7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
    8. Remove belt from power steering pulley and set aside.
    9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
    10. Install right side splash shield and lower vehicle.
    11. Position belt around power steering pulley and release tensioner.
    Nov 23, 2008 | 1995 Oldsmobile Aurora
    Dryers Logo
    Top Estate Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Terry Schneider
    Are you an Estate Dryer Expert? Answer questions, earn points and help others
