Question about Pit Cycling
When i pull the excellerater right back it dont have any performance whys that?
  • 133 Answers
You could check 1 of 3 things
1. the type of gas/ mixture
2. check the oil ( regular oil changes )
3. exhaust leak from the head
Posted on Mar 24, 2011
I'm coming up to 25000 miles service and I've been told that I need to change the shell valves ??? Is this correct
It is a legitimate service. There are 2 main ways to perform the service - either by disassembling and cleaning out, or by use of an engine cleaner or valve cleaning kit. Some of the options are sprayed in through intake while car is running and it helps get the carbon deposits off the valves. I knew a place that did this service and the engines would smoke during the service as the carbon was being taken off - but seemed to straighten right back up. Here's an article on the whys and hows... Intake Valve Deposits in Gasoline Direct Injection Engines
May 11, 2016 | Motorcycles
My 2000 HD Chevy pickup starts but acts like it starving for fuel or overloading when you excellerat.
Have a fuel pressure an flow test done ! Plus an exhaust back pressure test an have it hooked up to a diagnostic scan tool too .
Nov 10, 2015 | Cars & Trucks
My little echo creeps into intersection when i put my foot onto the excelerater Its very scary. It happens in the morning when left in garage.
Sounds like a transmission problem, and a dangerous one. You should take it to a good transmission specialist as soon as possible. Automatic or manual?
Jun 10, 2015 | 2000 Toyota ECHO
Orion tv picture only comes on when heated up whys this
Check and replace the CRT base connector socket. It is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 26, 2014 | Televison & Video
I have a 2007 pt cruiser and once and a while it will start studering real bad when your driving exspecialy if u push the excellerater but if u turn the car off then back on it resets, and it dont do it...
As for the sputtering it could be a sensor or in need or a tuneup.As for the transmission slipping i would have a mechanic look at it. That could be serious problem...hope this info helps and if so Please leave rating on this post and good luck.
Aug 15, 2012 | 2001 Chrysler PT Cruiser
Evry time i get 2 a junction my suzki cuts out like there is no fuel and takes a couple of mins 2 start back up whys it do that
replace your fuel filter or pull off your carburater n take it to bike shop 4 avibration cleaning oh first clean your air cleaner 2 it could be chocking 4 air
Apr 11, 2011 | 2003 Suzuki GZ 125 Marauder
Iv got a psp and im trying to connect to my internet but it keep sayin " error has occurred exchanging key information has timed out " whys that
you prob dont have the right network key entered... either that or u didt put the wep,wpa1,wpa2 or whatever else network setting u have on your router set too...
Sep 11, 2010 | Sony Video Game Consoles & Games
1986 f 250 diesel with C6 transmission. it doesnt shift up until 2500 rpm and it will shift down on me at around 1800. this just started. i have checked i do have vacuum. thank you
there is a rod that runs from the injection pump to the trans on the drivers side. it should move freely and there should be a spring that holds it forward so that it only pushes back when you push down on the excellerater.
Feb 06, 2010 | 1983 Ford F 250
Cycling Logo
35 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
