Question about Panasonic DMR-ES35VS
My panasonic dmr-es35v dvd player will not operate, It goes into a 'no read' mode also will not go into a stand-by mode
  • Panasonic Master
  • 508 Answers
The 'No Read' error is the DVD-RAM drive - the laser and/or spindle motor assembly has failed. As for standby mode not working, that would be an issue with the main microprocessor on the motherboard which could be expensive to replace (manufacturers no longer provide individual components; they provide exchange boards if available), making the unit virtually uneconomical to fix. The cost of a replacement DVD drive could cost anywhere between $150 and $400 plus fitting and firmware upgrade/reset.
The 'lock-out' you describe, would probably be an issue between the PSU and the main microprocessor (as mentioned above). Because you also had a 'No Read' error from the DVD, this unit, sadly, is not really worth fixing - BUT, you can always take it to a service centre, to get a quote and second opinion on likely cost(s) involved, at least then you can make a positive decision afterwards as to whether you want to go further with it or not. Up to you.
When you add it all up, you may find the total cost(s) to restore this unit to original working condition (if that's possible) may exceed the price of a new unit which can do the same thing this one did when it was new around 4 or 5 years ago. You have too many faults with this one.
Whichever is cheaper and easier for you - don't waste money on repairs if the quote you get is too high - buy a new (or refurbished) one with (optional) extended warranty and/or extra features - but only as a last resort, and keep this unit's remote if you do.
Posted on Mar 23, 2011
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
DMR-ES35VS: How do I connect my Panasonic DMR-ES35V through a ...
Put the main aerial into the set top box,then take a male to female fly lead and connect it to your panasonic,then take another fly lead from the panasonic into the tv.If you have two scart sockets on each unit and the tv you can connect one into the tv from the box and one from the panasonic into the tv,then you can connect the box to the panasonic so you could record from the box.
May 05, 2010 | Panasonic DMR-ES35VS
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Cannot play europen DVDs
Panasonic and JVC are harder models to find Region free codes for but you may want to try here or here
Sep 13, 2009 | Panasonic DMR-ES35VS
Need help with hook up
the exact diagram can be downloaded free at...
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
If I helped you, please take a moment to rate (help) me! Thank You for using FixYa!
Apr 06, 2009 | Panasonic DMR-ES35VS
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
Dvd/vcr combo Panasonic dmr-es35vs
I also encountered a similar problem and did some research on the internet. The way to fix this problem is hold the 'Enter' key and while holding the enter key, press number 1 for a few seconds until the display changes to C1 or SET 1 error goes away.
This should fix the problem. Atleast it worked for me. All the best!!
Sep 24, 2008 | Panasonic DMR-ES35VS
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
IS MY DVD COMBO REGION FREE
Yes the Panasonic DMR-ES35V is a multi region player.
Jan 01, 2008 | Panasonic DVD-S35 DVD Player
Panasonic DMR-ES35VS Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
