Question about Briggs & Stratton Garden
I need a wiring diagram for a Briggs and Stratton 16 hp vtwin vanguard mower
  • chad788 Mar 23, 2011
    Briggs does not make mowers. What is the make and model of the mower itself? This is usually found under the seat or on the rear panel.
3 Suggested Answers
SOURCE: i need to how to connect the throttle to the carb
Don't have a diagram. It's pretty simple, tho.
There is a throttle cable run from the throtle control lever on the dash down to the carburetor. There is a lever on the carburetor -- usually this has a hole in it where the end of the throttle cable hooks.
There should be a clamp in that vicinity to hold down the throttle cable housing to allow the cable inside to move back and forth without moving the cable housing,
Posted on May 06, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
Snapper mower 42 inch with brigg stratton vanguard 16 hp v twin engine lopes when not under load
I would start by cleaning the air filter and the spark plug, or replace both if they are old.
Aug 08, 2014 | Briggs & Stratton Garden
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Wiring diagram for a E2000 greenfield, OHV Vanguard motor
Hi...How did you go? Did you end up getting one? I need the same if you can helkp me out. Cheers Glen
Mar 17, 2009 | Briggs & Stratton Garden
Garden Logo
111 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
