Question about Prosonic Televison & Video
I have a Prosonic 42"
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
Posted on May 28, 2008
  • 1689 Answers
SOURCE: Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Posted on Jun 03, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 5568 Answers
SOURCE: Hello "experts", My Panasonic Viera TH-50PV600
That's a fairly common indication that a component in the main power supply called an 'electrolytic capacitor' is fading away. These are used as filters and in feedback paths in switched mode power supplies and one of the parts on which mfr.'s safe a nickel or two. If these parts are not rated for the type of service they perform (higher frequencies and ripple current) they chemically break down and lose value until they no longer can serve their purpose.
If you open the back of the set after allowing a number of hours (overnight is better) with the plug pulled, look for a smaller circuit board with larger than average parts. Some of these will be blocks (transformers and chokes) and it will have cylindrical 'cans' that are mounted 90 degrees to the board. Look for a part number which may be on a sticker. If you can find this, contact Panasonic service in your area and ask about repair or replacement cost of this board. If either causes a faint heart, check on the site below to see if they happen to have this board on hand, it may save some money:
Jimmy's Parts
Subassemblies are normally plugged in and won't require soldering to replace.
Posted on Mar 19, 2010
I bought a LG 42LB1D LCD tv about 5 years ago.I hardly watch this tv. When i watching dvd few days ago all of a sudden i see only BLACK screen sound is OK and remote control is not consistent sometim
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 11, 2014 | LG 42LB1D 42 in. HD-Ready LCD TV
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Sanyo 42 inch Mode Number: DP42647. I bought it 2.5 years ago, and suddenly, the video is out. The sound is ok, as well as the "power" green LED. By looking at other forums, it seems...
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
May 20, 2017 | Sanyo 42 in. LCD TV
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Hi, I have a Samsung Tv(42") model HL-84266W that
Ur tv have CRT tubes coolant problems.Must be replaced CRTS coolant chemicals,to clear it up.Tries websites like, to buy these coolant kits,it also came with a tutoring DVD also.
Jan 01, 2011 | Samsung HCM4215W 42" Rear Projection...
Screen Goes Green, with Lines and jumps. 42LG30 1080p TV.
The TV is under a LG factory 1 year warranty.
Unless you bought a refurbished unit which has a 30 day warranty.
Contact LG @ 1 800 243-0000 for warranty repairs.
Be sure to have the...
Date of purchase
And Product code.
The information is on the back of the TV or on a small white tag
on the side of the TV.
Jan 09, 2010 | LG 42LG30 42 in. LCD HDTV
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Dec 07, 2008 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Prosonic Televison & Video Experts
Jaime Hernandez
rugby prop
Are you a Prosonic Televison and Video Expert? Answer questions, earn points and help others
