Question about RCA D52W19 52" Rear Projection Television
My RCA D52W19 TV HAS GOOD PICTURE BUT NO SOUND, WHAT COULD IT BE.
  • RCA Master
  • 2,098 Answers
If you've confirmed that the mute is not on, this is an indication that the audio board inside was gone bad. This is where the internal speaker was connected. The common faulty parts there is the sound output IC(mounted in heat sink) and some of the resistor. This IC fails because of constant heat exposure and also aging. Once replaced with new IC and some of the resistor, the sound will back to normal again.
Also, bad solder joints(dry/cold solder) is to consider in that board. This is hard to spot, I would advice you to find it in the brightest area or use a table lamp/portable lamp and magnifying glass.
If you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for a qualified technician to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 22, 2011
  • 1030 Answers
SOURCE: rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Posted on Dec 07, 2007
Slinteriors
  • 8617 Answers
SOURCE: rca tv wont come on at all
Look on the back for the chassis number. RCA and phillips need the chassis number to be diagnosed.
Posted on Feb 02, 2008
ladywinn
  • 5138 Answers
SOURCE: rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Posted on Feb 14, 2009
SOURCE: RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Posted on Aug 14, 2009
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
Posted on Oct 07, 2009
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
RCA Model D52w19
One thing that comes to mind is the two main connectors on the power/deflection board. They have ribbon cable in them. If they are white in color. One of them plus the one on the convergence board that is the same size, needs to be replaced. If they are black they are good. Part number is 258686. If your serial number is between G13XXXXXX and G26XXXXXX this is a very good posibility.
Aug 04, 2008 | RCA HD52W58 52" TV
No sound
Is the DVD player connected to the TV via component cables? If so you should have 5 connectors total that will bring picture and audio information to the TV.
Jun 22, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 power but no picture...
Solder around flyback pinns this should fix it.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
