Question about Gateway FPD2275W LCD Monitor
LCD monitor goes blank
I recently attempted to install a used Gateway LCD flat screen monitor onto my HP system (running Windows XP and the Intel Extreme Graphics monitor driver). When the monitor is first turned on, the power light is green and the monitor displays output, but within a couple seconds the monitor's power light goes from green to yellow (as though entering sleep mode) and the screen goes blank, and nothing 'wakes' the screen up. I've checked all connections, and they seem good. No bent pins, etc. Then, when I detach the flat screen and reattach my CRT monitor, the CRT functions properly. Do I have a defective monitor, an incompatible driver, or what?  when computer isturned on a few seconds into startup the goes blank.turn the montor off and on one or two times and it seams ok
  • 3,940 Answers
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Posted on Aug 03, 2008
How to fix this compaq evo d510 sff
D510 (very old) , looks XP like to me. stuck in VGA.sys, default video mode, lacking the real driver. (xp did that for 17 long years now)
I cant see inside your PC nor scan it with sniffer3. app.
so no answers possible. (just this)
it a desktop and has 2 VGA jacks or 1. (not told)
you never said what's inside.
so no answers but 1.
this pc could have 100s of video cards inside or not. (vast, can list them endlessly)
even 6 by HP sold as options day 1, again i cant see inside.
but XP driver for the onboard chip is at intel
not at HP it's too old now,(no support now)
not at MS, , XP is dead. XP support ended 4 years ago.
so has it for sure for XP, super easy to get at (ask)
but the XP driver does not work on W7 up. (but might if installed (risk)
using the compatible mode, to install the driver.
doing that is tricky want to learn?
here is a wiki page
that shows why XP drivers may not work
on the never windows,(
i call it the XDDM/XPDM snafu.
the steps are convoluted.
run the setup file in XP SP3 compat mode.
extract in and find the Inf file that match your
video GPU chip
then run that INF. (right click it and pick install)
there is no other way to install wrong video driver in W7
ever do this?
Dec 23, 2017 | Compaq Computers & Internet
I have an VGA adapter on the cord b/c 15 pin male/9 pin female is almost impossible to find. Anyway when I connect to two monitors to the pc only on monitor comes on the other does nothing. comfirmed both...
9-pin female to 15-pin male RS232 adapter
This = NO
You cannot run dual monitors off of the motherboard.
BIOS will assign only one IRQ.
(Interrupt ReQuest )
That 9-pin connector (C) is a Serial port. This = No
You need a graphics card.
Don't be thinking of one monitor to motherboard, and one monitor to graphics card.
One IRQ, and it's assigned to either the -> motherboard graphics (Integrated), or a -> dedicated graphics card.
Two monitors to graphics card.
I am using a lesser model;
ATI Radeon 9250, and it's a PCI graphics card.
Goes in a white PCI slot.
My PCI-Express graphics card gave up the ghost. (8 years old. It's cool)
I replaced it with the Radeon 9250 so could run dual monitors again.
Does fine for on here, Adobe Photoshop 7, YouTube, etc. Not a gamer.
(I have a Powercolor HD5450 PCI-Express graphics card I'm going to use, when I get off my duff, lol! Requires a 400 Watt power supply)
I use an HP 2009m 20-inch widescreen, as my Primary monitor, (Left side of computer desk), and a Philips 26-inch HDTV as my Secondary monitor. (Right side of desk)
Do you have two VGA (CRT) type monitors, or is one a flat LCD screen digital monitor?
Some flat LCD screen monitors have dual hookups.
One for a VGA cable, and one for a DVI cable,
If you have two VGA monitors that are the CRT type, (Looks like a small TV), and your graphics card has 1 VGA port, and 1 DVI port, they make a VGA to DVI adapter. Just make sure you get the correct one.
VGA port on graphics card is Female.
DVI cable connector is Male.
This is the usual standard.
This is the type of VGA to DVI adapter that is required,
ALWAYS, install the software off of the Installation disk that comes with the graphics card -> FIRST
Install the drivers, and the user control panel.
(Driver: Small piece of software that allows the Operating System to communicate with a device.
The graphics card is the device, do not know what version of Windows you are using.
User control panel = ATI - Catalyst Control Panel. Nvidia - Nvidia Control Panel )
Do Not worry that you will loose graphics, after installing the graphics card software. Windows will Not use the software until THAT graphics card is installed.
Then after finished close all windows, go back to your desktop screen, and turn the computer off.
Unplug from power, FOLLOW Anti-Static Precautions, and physically install graphics card.
(Need to know about Anti-Static Precautions please post back in a Comment)
Set your main, or Primary monitor on the left side, Secondary monitor on the right; of your computer desk.
Turn the monitors on. If a CRT type allow them to warm up.
Turn the computer on. Once Windows has loaded your desktop screen will be on the Primary monitor.
1) Right-click on an empty area of your desktop screen
2) Left-click on Properties
3) Left-click on the Settings tab
The blue No.1 monitor icon is the Primary monitor
The blue No.2 monitor icon is the Secondary monitor.
4) Left-click on the Secondary monitor icon.
5) Left-click in the empty square box to the left of -
Extend my Windows desktop onto this monitor
6) Left-click on Apply at the bottom right
7) Left-click on OK at the bottom left.
Your desktop screen will now be on both monitors.
(Advisory comes up asking if you wish to keep settings? Yes)
Open your internet browser.
Move your mouse cursor to the Right side of the blue frame/border.
WHEN your mouse cursor turns into a Double-Headed Arrow, hold the Left mouse button down.
It is a little tricky to keep the mouse cursor as a Double-Headed Arrow. Must be that, and then hold the left mouse button down.
Holding the left mouse button down move your mouse to the Right, and drag the blue border of the internet browser to the Right.
Keep dragging until it is all the way to the right side, of the Secondary monitor.
Now you have your internet browser on both monitors.
I run the internet browser on my Secondary monitor, (26-inch HDTV), and use the Primary monitor to look at computer functions, motherboard manuals, etc.
Or I move the internet browser to the Primary monitor, play music videos from YouTube, and use the Secondary monitor for Photoshop.
The world is your oyster.
So there you have it. You need a graphics card, and it has to have dual monitor inputs. (Ports)
Splitter cable thing? I wouldn't bother.
Buying a graphics card:
Depends on what you want to do with it for one.
You can see the simple stuff I do, doesn't require much graphics power.
(More than Integrated Graphics, though, and can't use dual monitors on Integrated Graphics)
The next concerns are what type of graphics expansion slot/s do you have, and how much Wattage (Power) the Power Supply has.
You have a 300 Watt power supply, unless it has been replaced,
(Scroll down; Power Supplies)
Your motherboard has 2 white PCI slots. If one is available it can be used for a graphics card -> Not recommended
Your motherboard has one Black PCI-Express x16 expansion slot, that is used for a graphics card, also.
It is right above No.1 white PCI slot.
Highly recommended.
(Gently Pull UP on the PCI-Express x16 slot -> Lock
It looks as though you press down on it, when installing, or removing a graphics card )
So when looking for a graphics card, look for PCI-Express graphics card, and system requirements / minimum power requirement; states 300 Watt power supply, or greater.
For additional questions please post in a Comment.
I know that is a lot to take in all at once. I can clarify anything you need clarified.
Nov 09, 2012 | Gateway GT5404 PC Desktop
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Mar 16, 2009 | Computers & Internet
Display is upside down
Jun 02, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
Graphic Processor Upgrade
Try to install the latest drivers here:*%20XP%20Professional&lang=eng
And attempt to use the intel application in the system tray to configure the resolution, not the windows display utility.
Dec 19, 2007 | Computers & Internet
Monitor problem
This is a classic case of Windows generic graphics card driver. You need to find out what type of graphics card you have fitted or what onboard graphics chip you have. If it's an AGP card go to my computer>properties> hardware tab>device manager and look down list for display adapters, if it's onboard then it maybe an intel chip. Make note of the make and go to the relevant web site for the drivers
Mar 08, 2007 | HP vs19 (Silver) 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
464 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
