Question about Electronics - Others
I want to change my rv wiring from 2 12 volt batteries wired parellel to 2 6 volt batteries wired series, then add 2 more 6 volt batteries wired in a serie then wire the 2 banks of 6 volt batteries parellel to the rv in my mind this would increase my amperage. I am a wiring dummy
    Genius:
  • 1,150 Answers
To increase amps your best bet is to get two deep cycle marine batteries with high cranking amps
Posted on Sep 18, 2011
I have a 2001 Trace legand series inverter modle L1512. Can i switch to Lifeline LL-GPL4CT 6 volt batteries with no changes to inverter?
If the inverter is intended for 6 volt batteries, and I doubt it, then yes. However, it is common to connect two six volt batteries in series to get 12V, which most RV inverters use. I have four 6 volt, series parallel connected batteries in my home providing 830 AH to run the house during the peak periods of the day. I have never had a problem with this set up.
Aug 08, 2017 | Inverter Electronics - Others
How do you hook up the 2 6 volt batteries from the coach and. The 12volt nattery. With a solar panel for the batteries for a 2000damon intruder?
Hi Jackie,
I think that if you search online for "Damon intruder 2000 wiring diagram" you'll get hits on the best websites to answer your query. Also, you'll probably get several images which you should be able to blow up in size.
Try
iRV2 Forum RV Forum Community and RV News
see also. RV Net RV and Camping Forum RV Trailer Camper Motorhome Camping and...
Aug 03, 2015 | Cars & Trucks
How to wire these speakers in series or parellel cirecuit?
wire speakers in parallel as the power diminishes after each speaker and before the next one if wired in series
Apr 20, 2015 | Pyle 6.5in ceiling w/70 volt spkr trans...
Need to wire up 3 batterys on 83 fleetwood rv
If its a twelve volt system than you will wire them in parallel. This means that the all the positives will be connected to each other and all the negatives will be connected to each other. If this is a 36 volt system you will wire them in series. This means you will wire the first battery positive to the vechicle and the negative to the second batteries positive. The second batteries negative will go to the third batteries positive. The third batteries negative will go to the vehicle. This will give you 36 volts.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 14, 2012 | Vehicle Parts & Accessories
How do i wire my golf cart for one light and one horne 6 volt batterys 36 volt system
The batteries are connected in series (6V + 6V+ 6V +6V +6V +6V), Select only two batteries (CONNECTED TO EACH OTHER in series FROM POSITIVE TO NEGATIVE (last two batteries preferred) and run two wires (one black one red) from the positive (red) and the negative (black). purchase two switches one MOMENTARY PUSH BUTTON AND ONE TOGGLE. Split the two wires by ADDING another length to the middle of each wire respectively Add the switching devices by connecting the red wire to one of the terminals. The other terminal will then receive Another length (red) to be the connected the same way to the horn (push button switch) The black wires (ground) are to be connected to the other terminal of the horn and light. NOTE: it is advisable to add a 15A in line fuse to the red wire near the battery.
Oct 14, 2011 | Sport & Outdoor - Others
How to connect 4, 6 volt batteries on a 2005 fleetwood expedition
Assuming that you want a 12 volt equivalent, you should wire the batteries as in the following diagram.
If you are looking for some other configuration, post a reply.
Dec 27, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
Sep 21, 2009 | Garmin Walking Cart Mount For Golflogix...
Need a wiring diagram for a barbie 12 volt two battery jeep !!!!!
When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
Nov 25, 2008 | 3d Rose Londons Times Funny Society...
Electronics - Others Logo
293 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
