Question about Acer Aspire One Netbook 8.9" Notebook
Acer one net book-- blue screen,will not go in to safe mode,can not boot from cd.running xp,will not do anything except give me the blue screen--unmountable boot volume..any tricks i can use.
  • g hynes Mar 22, 2011
    trying all the suggestions but it still goes to blue screen.it may have to go in the shop.
    Genius:
  • 1,542 Answers
Hi
If you are not worried about loosing everything on your hard drive then you could try this it may still work for you
turn off laptop
turn on laptop also keep pressing alt=F10 a few times and hopefully this will take you into the acer recovery management
if so just follow on screen instructions it may ask you for a password if you haven't set one up your self the default one is quite often 000000 that is ( 6 zero's )
hope you get it sorted
Posted on Mar 22, 2011
  • Margaret Glanville Mar 22, 2011
    Hi
    sorry that you are not having much luck
    you could try hitting the f8 key on statup
    and try to get to the cmd option
    which should give you a black box
    type into it chkdsk and see if it will do a check disk/repair disk for you
    Sergeant:
  • 187 Answers
Try to enter into BIOS Setup. Then change the boot order.
Thanks & Regards,
(-_-)
Acer Aspire One, Windows XP. Nothing will open when clicked except internet, and will not allow downloads of virus software. Even when run in safe mode.
useing annother computer download this iso http://download.bitdefender.com/rescue_cd/ and burn to a cd, place said cd into you cdrom, and select it to boot from.. (can be set in Bios), ensure a network cable is connected to your computer during the boot up process.. then follow on screen prompts to remove the rootkit from your computer...
Aug 25, 2011 | Acer Aspire One PC Notebook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire one netbook won't boot up. blue screen of death, stating there is a driver problem
try to load your windows in safe mode and then logon admin
then remove the display drivers then start the windows in normal mode.
Jan 19, 2011 | Computers & Internet
My Acer netbook will not boot. It gives me a blue
Start up in safe mode (press F8 key at boot) do a system restore back to a time when you know it was working
Apr 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Acer aspire one wont start into normal windows, only safemode
Did your system come with any software? I know when I bought my aspireone it did not. However, You can purchase a thumbdrive with at least 4 gb of space and if you have a copy of windows xp of the same version as that which is loaded on your aspireone (should be windows xp home edition) and you can use a program like magicISO to create a copy of the windows xp cd onto the thumbdrive.
Hope this helps, and I would be more than happy to give you more specific support as needed.
Good Luck!
Jesse
Jan 06, 2010 | Acer Aspire One AOA150-1635 Notebook
Can not boot
what's the 1st thing you see when you try booting? it should be black with white words detailing your boot cycle. if youre not seeing this, its hardware.
hopefully your blue screen comes later, which means it's more likely software as windows is trying to load. I assume this is what it is since you see an avast error.
i think F8 is safe mode-- are you sure you're pressing F8 every second or two as it boots to get into safe mode?
what did you do right before this started happening to you?
Jan 31, 2009 | Acer Aspire One PC Notebook
System Service Exception Error (Blue Screen) - Acer AX1200
If you can reboot to Safe Mode and select "Last Known Good Configuration" it will be best but if you can't then you have to completely shut- down and reboot with your Restore or Windows CD and select the options to do a "Repair"
Jan 02, 2009 | Acer Aspire 3680 Laptop
Screen freezes
If you can manage to access the safe mode troubleshooting please do it. By pressing F8 afre the POST and before windows loads. Select Safe mode and let 'em continue load the safe mode desktop. However if the safe mode won't work. You need to reinstall the system. You can use your compliment Recovery CD in doing so. Hope this will give you hints.
Best regards,
Rosener Guyano
Feb 14, 2008 | Acer Aspire 3690-2196 Notebook
Unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Dec 19, 2007 | MSI K8MM-V Motherboard
Acer Aspire One Netbook 8.9" Notebook Logo
621 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
