Question about Mitsubishi WD-65733 65" HDTV
How much does it usually run for a tech to come and clean the dust off of the light asm?
  • Mitsubishi Master
  • 2,098 Answers
Hi Jackie,
This will actually $200 more or less depend on the technician. If the technician is come from the service center representative it will cost you $200 more but if he is a walk-in(not from service center) technician may charged you $200 or less. I would advice you to look for a qualified walk-in technician to save some money. You may ask your friend if they can recommend you an experienced one.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 22, 2011
My air conditioner constantly turns off it was running great then now i cant keep it running or staying on
Hi
Are the filters clean of dust[first thing to check and often forgotten]
There are many faults that affect air conditioners, most are only for trained service techs but you could check out the return air temperature sensor if you can see it. Usually situated on r/h side of indoor unit, it measures the air being drawn from the room back to the unit, if it is covered by dust it can send the wrong info to the control board causing the unit to shut down before desired temp is reached.
Mine started to do this, a strong puff of air from an air bed pump (don't touch the sensor unless you know what you are up to..) fixed it.
You could look at the outdoor unit for ice build up(you don't say of the unit is cooling or heating?) excessive ice
could be a faulty defrost sensor.
[tech job]
Jul 02, 2016 | Heating & Cooling
My pilot light is weak and won't stay lite.
try cleaning the pilot light jet, usually gets dust etc inside it. clean it with a pin. but remember do not mess with gas appliances if you are not confident enough. as being cold will be the least of your worries lol
Feb 16, 2012 | Heating & Cooling
Is there a fuse or relay or micro relay for the CHMSL on 98 sts
check the lt blue wire at upper lamp,(under trunk lid trim panel) for 12 volts when brake is applied. if no voltage,check same color wire at brake lamp switch for voltage.(by brake pedal).if no voltage replace stop lamp switch asm. if voltage is detected at rear by lamp then replace CHMSL asm.(center high mount stop lamp). this lamp is made of many LED's,if some work and some don't you will need to replace lamp asm. can be repaired by a trained GM tech, possibly. there is no seperate fuse or relay for this lamp,only a stop lamp fuse.
Nov 12, 2011 | 1998 Cadillac Seville
My dell d620 is very heat using ofter some time fan speed is very slow whate can idow it
It needs cleaning out, there's probably loads of dust/fluff blocking the ventilation slots, CPU fan and air ducting inside.
Dec 02, 2010 | Dell Latitude D620 Notebook
Service Heater light is on... what does that normally mean?
This is usually low flow. Try cleaning the baskets and make sure the filter is clean. This will usually fix the problem.
Nov 27, 2010 | Sta Rite SR400NA Max E Therm Pool Spa...
Refrigerator fan running not cooling
Good day,
That is the compressor not running. Could be a bad compressor, or one of it's starting components.
You can remove the start components from the compressor, by removing the cover, and pulling them off the compressor pins.
Any decent sized appliance parts house will test the components, usually made up of the overload protector, start relay, and on some models a start/run capacitor.
If any parts check bad, replace them, if they all check O.K. then you will need the services of a trained service tech.
Feb 20, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Brother IntelliFAX 4100 pickup roller
Need more info. Do you need help in replacing the roller? If so, it is a big job. You have to completely remove the doc feed asm and all covers to get to the roller shaft asm. Best to let a tech do it for you.
Have you tried cleaning it with some roller cleaner. Try a little bit of Goof-Off cleaner on a cotton rag.
Aug 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
May 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Looks like dust spots behind screen
I had the same problem and had a tech check it out.
It turned out to be dust on lens and mirror.
cleaned them and good as new.
Ihope this works for you.
Dec 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi WD-65733 65" HDTV Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
