Question about Toshiba Mini NB205-N313/P Netbook
My arrow keys are disabled, how do i turn them back on?
    Sergeant:
    Novelist:
  • 185 Answers
Hi there
if you hold down FN (bottom left of keyboard) and then press INS button together (inbetween F12 and DEL)
That will disable the scroll lock.
Hope this helps and please rate thanks
Posted on Mar 22, 2011
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
Tip
Lenovo G430/ G530 Function keys
<p><span>The following describes the features of each function key.</SPAN><br> <p><b><span>Fn + F1: </SPAN></B><span>Put your computer in sleep mode.</SPAN><br> <p><b><span>Fn + F2: </SPAN></B><span>Turn off/on the LCD screen back light.</SPAN><br> <p><b><span>Fn + F3: </SPAN></B><span>Shift to other connected display devices.</SPAN><br> <p><b><span>Fn + F4: </SPAN></B><span>Switch between wide screen and normal mode.</SPAN><br> <p><b><span>Fn + F5: </SPAN></B><span>Enable/disable the built-in wireless device feature.</SPAN><br> <p><b><span>Fn + F8: </SPAN></B><span>Enable/disable the touch pad.</SPAN><br> <p><b><span>Fn + F9: </SPAN></B><span>Play/pause Media Player playback.</SPAN><br> <p><b><span>Fn + F10: </SPAN></B><span>Stop Media Player playback.</SPAN><br> <p><b><span>Fn + F11: </SPAN></B><span>Skip to the previous track.</SPAN><br> <p><b><span>Fn + F12: </SPAN></B><span>Skip to the next track.</SPAN><br> <p><b><span>Fn + Insert/NmLk: </SPAN></B><span>Enable/disable the Numeric keypad.</SPAN><br> <p><b><span>Fn +Delete/ScrLk: </SPAN></B><span>Enable/disable Scroll Lock.</SPAN><br> <p><b><span>Fn + PrtSc/SysRq: </SPAN></B><span>System request.</SPAN><br> <p><b><span>Fn + up/down arrow: </SPAN></B><span>Increase/decrease display brightness.</SPAN><br> <p><b><span>Fn + right/left arrow: </SPAN></B><span>Increase/decrease computer volume.</SPAN><br> <p><b><span>Fn + PgUp: </SPAN></B><span>Move the cursor to the head of the line.</SPAN><br> <p><b><span>Fn + PgDn: </SPAN></B><span>Move the cursor to the end of the line.</SPAN>
on Jan 19, 2011 | Computers & Internet
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
May 22, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
When I use the remote to turn tv on, the screen says locked
Hello
Your Philips TV is locked. Tu unlock it, do the folloing.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK
Jan 29, 2011 | Philips 37PFL5332D 37 in. LCD Television
I'm trying to disable the power saver on the printer
Title:
How do I enable/disable the printer power save mode setting? Description:You can make a setting from the Menu screen on the Control Panel.
  1. Press the Menu button. The menu System is displayed.
  2. Press the right arrow key to enter the menu.
  3. Press the up/down arrow keys to select the menu Power Save Time.
  4. When the Power Save Time is displayed, press the right arrow key.
  5. Select the setting using the up/down arrow keys.
Oct 20, 2010 | Office Equipment & Supplies
I am locked out of my acer laptop. It was protected by a finger scan, but when we disabled it and turned the computer off, when. We turned it back on it asks for a password that we don't know.
WHEN YOU TURN ON YOUR COMPUTER PRESS ESC TO GO TO SYSTEM SETUP BIOS. IN BIOS LOOK FOR SECURITY IN SECURITY THERE SHOULD BE THE FINGERPRINT ENABLE DISABLE USING THE ARROWS MOVE TO IT PRESS ENTER SWITCH TO ENABLE USING ARROW KEYS PRESS ENTER. GO TO SAVE AND EXIT. THIS SHOULD BE A GOOD LESSON. IF YOU USE A GOOD SECURITY ON YOUR COMPUTER TO KEEP OTHER PEOPLE OUT, THEN USE IT ALWAYS.
PEACE
Aug 29, 2010 | Acer Aspire 5500 5570-2609 Laptop
Can you please tell us how to turn off the child lock off ?
Most of these sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jun 23, 2009 | Philips Magnavox 27MS343S 27" TV
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
My laptop arrow key is automaticaly press
Looks like your arrow keys are stuck and needs some cleaning. I suggest you to take it computer center where they can remove and clean buttons. Laptop keys are littlebit difficult to remove and place them back.
Dec 09, 2008 | HP Computers & Internet
Toshiba Mini NB205-N313/P Netbook Logo
186 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
