Question about Garden
After "resetting" the PRO-C I
  • dag0872 Mar 22, 2011
    I do not agree. The sprinkler was installed in 2004, with only the PRO-C controller. It was "on" all the time, and the lawn was watered in sequence, each station (total 4 stations) one after the other for the duration of the programmed "watering time": without "looping back". After the sequence was completed "one time", the watering "shut down", and began again the next day. It did not repeat the cycle again, and did not have to be turned off. The "master" timer (which I do not know where it is) should be controlled by the "PRO-C" which is the only visible module installed inside the garage.
    Your answer does not solve the problem. Will you be able to offer the solution?
    Daniel
  • dag0872 Mar 24, 2011
    Sorry, no solution. You are just telling me something I already did. Plus, I "have the manual" which is the same one found at www.hunterindustries.com, where I had gone first (before contacting FIXYA) to see if the manufacturer offered a solution in his web page. Since I could not find a solution to my problem I contacted FIXYA. Right now I am where I started. My next step will be to have the equipment installer come to my home. Thanks, but no thanks
    dag0872
    fi
    Guru:
  • 1,833 Answers
According to your problem you have done some incorrect programing in your pro-c . It may malfunctioned for a wrong program. Anyways reprogram it first. If you got the same problem again after reprogramming then it may need upgrade. For updating contact the nearest technician.
Before reprogramming visit www.hunterindustries.com to get the manual and follow the programing rules and the sprinkler fundamental.
Posted on Mar 23, 2011
  • 12,061 Answers
Www.hunterindustries.com/Resources/PDFs/Product_Guides/.../lit325w.pdf
Hi, well from what you describe, it actually seems ..well.. er.. normal? see a Timer, is a pretty dumb device essentially.
we have a device, that enumerates time, and by selecting start and stop times, the unit, will essentially, wait, until a time period has passed and perform an action, either going ON or OFF.
Now the Overall function is to start at the beginning, and step through the sequence, until the last one is performed, and then... it will "loop" back to the beginning, UNLESS there is an "Overseer" program that then completely stops, or inhibits the timer...
So really that's all a timer can do, and that is to cycle through the programming sequence, and unless commanded to Stop, at the end of said sequence, then all it can do, is go back to the start and begin the sequence again. It would do this until it was stopped, by some "External" action, IE: Someone turns the power OFF.
So I believe that indeed you are doing everything correctly..
If you want the timer to do it's task Once and wait until "Asked" to do it all again, you would need another timer, wired in series with the power INPUT, that "Times out" after say 12 - 24 hours, whatever.
This then will completely turn off the 2nd Timer, and stop the entire cycle.
So you would need a Master Timer, hooked up in series to your Slave Timer. The master controls the entire "Period" with the 2nd Timer controlling the interval inbetween, at the end of the inbetween period, the whole system is shut down, waiting to be activated again sometime in the future.
Posted on Mar 22, 2011
Radioshack pro 67 need to factory reset
I'm not all that familiar with the unit, but found these instructions for you at the link below. REMEMBER: you are going to erase EVERYTHING when you do this. Quoting manual:
RESETTING THE SCANNER If the scanner's display locks up or does not work properly after you connect power, you might need to reset the scanner. Caution: This procedure clears all the information you have programmed into the scanner. Before you reset the scanner, try turning it off and on to see if it begins working properly. 1. Turn off the scanner. 2. While you hold down the 2 and 9 keys, turn on the scanner." (End of quote)
Click on the link below and choose "Troubleshooting" from the menu.
RadioShack PRO 67 Scanner 200 0512
Jul 15, 2014 | Radio Communications
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
Need to progam radio for my stationsin my 2009 acadia can you tell me how
I think but don't quote me on it but GM is the same in most of their cars. Anyway, turn manually to the station that you want to program in. When it is on that station, the button you want to program it to just press in and hold until it sets. I know that sounds to simple and I hope I'm right for your sake. Good luck
Feb 11, 2011 | 2009 GMC Acadia
How can I switch my screen resolution on the Pioneer PDP-4270 from 480i to 720i or 1080i? HDMI cable is connected appropriately. I have tried new HDMI cables, and pressing reset to factory settings along...
Change the resolution on the cable box or satellite box, witch ever you have. A set by itself cannot change the resolution, if the cable is giving you 720p, that's what you'll see for that station. All stations do not transmit in HD. The best picture is only as good as they're giving you.
Dec 19, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
How do I reset the radio stations to be programmed into the radio? I did not receive an owners manual when I purchased my 2000 Mazda MPV Minivan
TRY THIS. GO TO THE STATION YOU WANT. PUSH AND HOLD THE SELECTED PRE-SET BUTTON YOU WOULD LIKE TO PROGRAM. PUSH AND HOLD TILL THE DISPLAY OF THE STATION BLINKS OR THE RADIO BEEPS. IT WILL BE FOR A FEW SECONDS. TO CHECK, TO THE STATION THEN PRESS THE PRE-SET BUTTON TO SEE IF IT STORED YOUR STATION. LET ME KNOW.
Feb 17, 2010 | 2000 Mazda MPV
Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
May 18, 2009 | Philips TP2784C TV
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
