Question about NetGear WGR614 Wireless Router
Could not find any compatible access point nearby. check the connection settings in the menu "internet" and try again. For help, visit the web site support.nintendo.com ... Error: 051110
  • 3,866 Answers
Welcome to fixya.com we are here to try and help you with your nintendo Wii
This error message you are getting is indeed a error timeout that resulted in a mis configured access point or did not find a access point.
You might want to check your security settings in your router by accessing the router via browser using a computer at 192.168.1.1 putting in the user name and password as well.
You want to select 64 bit security encryption for your router so the Wii can understand it. Most AP's "acess points" use WPA or TSKIP witch the Wii might not see as use able.
You also want to make sure your access point is broadcasting as well.
if you need additional helps on this please respond with the type of router you have along with the model number.
Thanks for using fixya.com
regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Mar 22, 2011
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
Tip
How to connect your Wii to the Internet.
From the wii home menu...Go to Wii Options in the lower left.Click on Wii Settings to the right.From this first list, click the right arrow.Now on page 2, click on Internet.Then click Connection Settings.From this list, click Connection 1.Then, click Wireless Connection...and then click Search for an Access Point.It will briefly search for any access points and when the screen comes up, click OK.There will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...When the next screen appears, click OK...and OK again.It will test the connection...And if successful, a menu will drop down. Click Yes to update Wii.Sometimes the prior screen is false, saying there is an update when there isn't and another window will appear...Now, back in Wii System Settings, click on WiiConnect24.From the following list click WiiConnect24.Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.Click Wii System Update...click yes...it will test your connection for a few seconds...an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one) Click Wii Menu to finish.
on Feb 18, 2010 | Video Game Consoles & Games
Every time I try to connect to the internet it my DS keeps 'No compatible access point in range. Check your connection settings and try again. For help visit suppoert.nintendo.com Error code:...
You can only connect to internet if someone is sharing their Wifi. If it is password protected, you won't have any luck. You're best off heading to Starbucks or McDonalds for free Wifi to connect to the internet.
Jun 18, 2011 | Nintendo DS Lite Console
Hi,my dsi i set the internet is work yesteday now is no work is sho unable to obtain an IP address. check your access point settings.Error code:052010-1.Ples hel mi.
Hi
Please check whether the below point will be helpful.
  • The DHCP settings of the access point and DS dont appear to be compatible.
  • Please check the DHCP settings of your router and try again.
  • If you have multiple connection files saved to your DS the error message you received can help determine which connection file may be experiencing a problem you error code says problem with connection file 2 .Please check
Feb 28, 2011 | Computers & Internet
How do i hook up my wii to the internet wireless
It is very simple
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
Once that finishes, go back to the main menu and try using the internet.
Also please watch this video for a walkthrough.
Feb 28, 2011 | Nintendo Wii Console
Just got a wii game system an I would like to hook it my rotter is a A90 750015-01
I can't get me kid off the Wii right now so I found this which should get you in the right direction.
and OK again.
Post came from : http://www.wiichat.com/nintendo-wii-online/5820-official-wii-wireless-internet-connection-guide.html
Oct 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
Getting the internet on
first you need to set up your Connection Settings under "Internet" in the System Settings Menu. Then you need to either "Search for an Access Point", in which your system will search for a nearby Wi-Fi hotspot, or choose "AOSS". When "Searching for an Access Point" turns up results, they'll be accompanied by a padlock icon that either shows as being locked (the WEP access code is needed) or unlocked (free access). If you're trying to set up access to an AOSS-compatable access point, then you'll need to press the AOSS button on the access point until it flashes.
Aug 02, 2010 | Nintendo DSi Black Console
On my nbintendo wii it wont connect to the
Check if your Router is compatible. If, but it is not wireless, buy the LAN adapter.
Nov 21, 2009 | Nintendo Wii Console
Getting to the router
From the Wii home menu...
  • Go to Wii Options in the lower left.
  • 2.jpgClick on Wii Settings to the right.
  • 3.jpgFrom this first list, click the right arrow.
  • 4.jpgNow on page 2, click on Internet.
  • 5.jpgThen click Connection Settings.
  • 6.jpgFrom this list, click Connection 1.
  • 7.jpgThen, click Wireless Connection and then click Search for an Access Point.
  • 9.jpgIt will briefly search for any access points and when this screen comes up, click OK.
  • 10.jpgThe following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to.
  • 11.jpgWhen the following screen appears, click OK
  • OK again.
If you have security enabled on your wireless router, then it will ask you for the password.
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
I dont understand how to hook my wii up to the internet
Official Wii Wireless Internet Connection Guide
For those unsure of how to connect your Wii to the internet wirelessly using a wireless router, here is my step-by-step guide for getting online.
First you'll need a compatible wireless router that can be found by going to the following site: http://www.nintendowifi.com/
From there, select your country, which will then take you to the WiFi index page. On this page, mouse over TECH SUPPORT at the top and from the menu that drops down, click on ROUTER INFO. Near the top of the following page, under the words "I don't own a wireless router, help me find one!" there is a "click here" link, which will finally take you to Nintendo's wireless router rating page, which you can look through to either see if your router will work or if you don't have a router, which one to get. For reference, if you live in North America, here is the router rating page.
The following are pics I took of my TV when first setting up my Wii's internet connection...
Jul 01, 2008 | Nintendo Video Game Consoles & Games
NetGear WGR614 Wireless Router Logo
388 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
