Question about Sylvania G-Netbook
I just ot done charging for the first time, and when i power it up it says Loading Device Drivers...it keeps doing this and wont stop. anyone know how tp fix this issue. I have a Netger N600 wireless router set up. my othe laptop works ut not this one... help please! thank you! Dino
    Genius:
  • 1,267 Answers
Since you cannot finish loading the operating system, you may have to re-flash your system. Please follow my TIP at: It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: It is looking for a password (WiFi NetworkKey) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on its back andusing a toothpick, insert it into the little hole about an inch diagonally fromthe right corner of the data plate, this will re-load a new copy of everythingincluding the WiFi RT28701 driver. sometime thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Posted on Mar 23, 2011
Keeps restarting itself
Sadly, some batteries will wear-out within a certain amount of months, and some may go even greater lengths until they will require replacement. This is one thing many people may not know when they are charging their device: Devices that use internal rechargeable batteries also use extra memory to know the charge limit point. So if you charge your the battery the device must know when to stop so the battery wont over heat and be damaged. This memory used to charge your battery can also be confused and malfunction, so that the device wont get proper power supply from the battery. This malfunction will usually occur when you plug in your device and use it at the same time or if you charge your device at random moments instead of letting it get to it's lowest power point then charging it again. I suggest that you let the device die fully, then let it rest for a few days, then while you charge it, have it off instead of on, that way the charge wont interfere with the screen info and let it charge as long as it is said to take on the manual that came with the device. If this fails, try 2 more times,if no luck after, have the company change your battery, dont try to change it yourself if it's bulit in, because some batteries require soldering a similar technique to welding something together, you can do this your self if trained, but you may also void a warranty if you have one with the device. If you'd like anymore info on your device leave a message for us at Game-Shabang official on Facebook, thank you
Oct 25, 2013 | Audio Players & Recorders
Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
Oct 24, 2013 | Computers & Internet
I have a ipod touch 4th 8 gb. It fell in water but was put in rice, screen cracked tho. It all works except when i use the usb port it doesnt make that one sound, show that it is charging, or it wont...
It could be dirty connections. 1) Turn off the device.
2) Take a charge cable and dip it in rubbing alcohol.
3)You then want to take the damp cable and plug it in and out of the device. Do this a few times, and then make sure it is dry before you plug it into any power source.
Aug 13, 2013 | Apple Ipod Touch 4th Generation
My zte wont turn on all the way
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 02, 2012 | ZTE Warp
My RCA Opal MP3 wont show up on my computer and it wont charge
This is battery problem, since it work with your computer directly, you no the computer power supply charge it directly so all you need do now is to get another battery and make sure you charge the new battery for some time before you power on.
Compliments and best of luck
Dec 25, 2009 | RCA OPAL M4001 MP3 Player
USB device does not work
Purchase a usb power plug to plug your device into the wall if it charges then your computer just needs to re install the device driver
Aug 29, 2009 | Sony NWZ-A816 Digital Media Player
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
SA5125/37 MP3 Player
Upgrade the firmware
www.philips.com/support
enter country
enter model #
click on model #
click on software & drivers
click on firmware upgrade - software
or, just open the Philips Device Manager and click on "Update"
Jul 23, 2008 | Philips SA5125/37 MP3 Player
Sylvania G-Netbook Logo
35 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
