Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Does the Panasonic TH-42PA60L have a digital tuner? The manual isn't very clear about this.
  • 643 Answers
Hook up rabit ears and do channel search. if there is channels will be saved.
Posted on Mar 22, 2011
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Dec 14, 2016 | Panasonic Televison & Video
I have a Panasonic TH-58PZ700U Which drops channels? Will have the channel one day and the next its gone then it will reappear! Is it the tuner going bad?
I would replace the DG Board. There hard to come by for this TV. I saw one on eBay about a week ago for $75.00 witch is a very good price for this part.
Jul 03, 2014 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
Th-p42g10a
If it has a digital tuner it should have a setting for auto program for that or the digital tuner may have a defect.
Jun 17, 2012 | Panasonic Televison & Video
Panasonic Viera TH-50PX80A. After lighting strike, inputs do not work.
The set MAY have a hard reset but you would have to call Panasonic to find out.
What happens with lightening strikes is RF gets into the set in two ways--via the power cord (usually a dead set is the result) and via the coax or cable fitting.
It sounds like it was the latter--it may have confused the microprocessor in the set(input issues) so unplugging set and or a box if used (receiver unit also!) may or may not help.
Surge protectors rarely operate quickly enough to stop this and even if the cable feed is protected stray RF can get past that also.
try my suggestions and then call Panasonic.
May 17, 2012 | Televison & Video
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Freeview not working
The tuner may be defective, or the reception is too poor for the set. A service tech who is qualified to work on your model of set can go out to your place with some field test equipment and verify the performance of the set for you.
The tuner and or IF modules, or main video processor module may be at fault. These modules can be replaced if necessary.
Before having a service call, read the instruction manual to make sure that all the user settings are correct to recieve programs from the tuner section. You can call the Panasonic tech support for assistance.
Jerry G.
Dec 18, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Need assistance installing an RF Tuner module (IMP-1200) into a Panasonic TH-42PD50U Display. I understand that there is some configuration needed. Please help !
Unplug power to the monitor before you attempt to install the tuner module and the Imp-1200 must be physically installed in slots 2 and 3 on the monitor.
Once card is installed, power on the monitor and enter the setup menu. highlight the OSD option then press and hold the surround button on the remote. This will enter a set of new options go to the digital slot option on page 3 and select slot 2. You should be done.
Dec 05, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
372 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
