Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you properly drain the fuel tank on craftsman 19.5 hp lawn tractor
    Problem Solver:
  • 14 Answers
The proper way is to remove the tank from the unit. You can also use a vacuum type device to remove all the fuel and water although it is very difficult to remove everything without removing the tank. Make sure you do not use a motorized vacuum device unless it is ul rated for use around gasoline!!!!
Posted on Mar 23, 2011
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not start after putting on new fuel filter and spark plug
This may seem silly, but if you put a new fuel filter in, did you drain the fuel and not put fresh fuel in the tank, and is the plug wire connected properly?
Good luck.
Jul 19, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to drain the old gas from my 20.0 HP, 42 in. lawn tractor. Thank you, Nancy
Remove the fuel line from the engine and drain the old fuel into a container. Follow the fuel line from the fuel tank to the engine. Anywhere along that line where you can disconnect it do so. The fuel filter is a good place to disconnect it and then you can replace the fuel filter when you connect it back up.
Apr 23, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My Craftsman 15.5 hp 42 in deck lawn tractor starts up and will run for few minutes, then cuts out really bad and dies. I have installed a new spark plug, new fuel filter, cleaned the air filter, and...
Sounds like dirt or water in your fuel system. Have you drained the bowl on the bottom of the carburator? There is a small bolt on the bottom of the bowl; be careful not to over tighten it. If you find anything but fuel in the bowl you may need to drain your tank as well.
Apr 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
try pulling the hose off from the carb and hang it into a pan so that gravity will help it drain into the pan...good luck
Mar 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
