Question about Citizen Stiletto Eco-Drive AR3015-53E Wrist Watch for Men
I own a AR3015-53E black Citizen watch. The band near the clasp has become quite scratched up in the 2 months that I have owned it. It is now showing the stainless steel. In order to fix this will I need to replace the band? Will the store replace the band?
5 Suggested Answers
SOURCE: Replacement Watch Band
I also have an Adidas watch, but cannot find a replacement.
Unfortunately, very unique for the contours around the body of the watch. Where can I find a replacement watchband?
Posted on Aug 03, 2008
  • 72 Answers
SOURCE: Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
Posted on May 24, 2009
  • 183 Answers
SOURCE: Where can I get a stainless steel replacement
You are right in that a stainless steel alternative is not typically thought of for this style of watch. The trick here will be finding someone who will customize head pieces that will fit the watch. There are a lot of talented craftsmen out there that can do this depending on where you are. I would start with the repair center for Precision Time. You can go to there website at PrecisionTimeCo.Com. Other than that I would call around to the local repair shops. You can also contact watch retailers to see if they have someone they recommend.
Posted on Sep 21, 2009
gemineye61
  • 831 Answers
SOURCE: How do you adjust the steel watch band of a
    Making the Band Shorter
  1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
  2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
  3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
  4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
  5. Making the Band Longer
  6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
  7. Step 2 Push the pin out so the link is detached from the clasp.
  8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
  9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
  10. Step 5 Repeat this process if you need to attach more than one link.
Posted on Aug 14, 2010
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Where to buy citizen Eco drive sky hawk a t clasp?
Hi, try http://watchbandsonline.com for replacement bands and parts. You may have to call them first for specific parts. Their phone number is 303-757-2245, and they are located in Denver, Colorado.
Thanks, Bill
Sep 08, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
Aug 14, 2010 | Citizen Watches
Anne Klein 10/5875 Y121E
You do noy need an exact Anne Klein band as all watch bands are made to specific measurements.
You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one.
Do not forget to rate, please.
Feb 27, 2009 | Anne Klein 108293SVBK Watch
Citizen Eco-Drive mens watch
Hi if it is anything like the other eco watches ---------
just under the clasp that lifts up you will find a little button, it is about 2mm long and there is one on either side, push these in with your thumb and index finger and it should release the clasp.
When you close it up,you will feel it `pop` back home again.
Dec 26, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Stiletto Eco-Drive AR3015-53E Wrist Watch for Men Logo
178 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
