Question about Whirlpool 30" Free Standing Electric Range WFE361LVD
How to replace the clock assembly (part #12001607) on my Kenmore range model #629.46775690. It is located on the front control panel just below the stovetop. Thank you.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Range
Okay...if the clock assembly appears to be working and the oven light comes on, but nothing else is working, I would double check your input power at the receptacle. You will need to unplug the range and check voltages at L1 to neutral and L2 to neutral. There should be 120VAC on each leg. It sounds like you are missing 120VAC on one side of the receptacle. I believe the clock and oven light will still come on, because they only utilize a portion of the input voltage. The elements, however, require 220VAC. Another way of checking for input voltage is to pull the range out so you can access behind it. Unplug the range and remove the back cover so you can see the terminal board where the power cord is connected. There should be three wires from left to right (BLACK, WHITE, RED). BLACK is L1, RED is L2. There will be 120VAC on each one of these lines when you plug the power back into the receptacle. If you place a meter from L1(BLACK) to NEUTRAL (WHITE), you should have 120VAC. The same is true when you place a meter across L2 (RED) and NEUTRAL (WHITE). If you connect the meter across L1 (BLACK) to L2 (RED) you should have your full 220VAC. If either leg (L1 or L2) is missing, the range elements will not work. If you check in this manner, you not only will be able to confirm whether or not you have proper input power, but you will also be determining whether or not the power cord is good. This may be a simple matter of a loose terminal in the back of the range, or...I have seen where consumers have wired them incorrectly. Check for the following in this order:
1. Double check you breaker to make sure it is not tripped (I know you said you already checked it).
2. Unplug range and check for proper voltage at the receptacle.
3. Remove back cover of range and verify correct wiring of the power cord.
4. With range unplugged, ensure all terminal lugs are properly tightened.
CAUTION: Do not attempt to tighten the terminal lugs with the power cord plugged in. Also, do not attempt to service the receptacle (repair or replace) with the power turned on at the breaker. Votages dangerous to life exists. I hope this information is helpful to you. If you have any questions or concerns, please post back with your comments.
Posted on Jan 31, 2008
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
  • 38 Answers
SOURCE: control panel
Call the guy back!!!!!
Posted on Nov 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: the control panel was replaced 5 days ago, but is
It appears your clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
Kenmore electric range model number 7909743380 the broiler stays on
I recommend that you visibly check that broil element for damage. If you see no damage where it could be shorting out to the metal in the range cabinet and the element was on, then you probably have a stuck relay on that clock control board in the console. You will need to replace the ERC. Here is the part to order. To replace the ERC, disconnect the power and pull the unit out. Once you can access the back, you will remove the back panel covering the back of the clock. Once removed, you will access the screws securing the clock to the control panel. Remove the screws from the clock assembly. Remove the wires, one at a time, and install them onto the new clock assembly as you remove them from the old clock. Install the new clock in reverse order once the wires are connected.
Jan 21, 2013 | Kitchen Ranges
Getting an F1 code on my kenmore range
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad
Feb 28, 2012 | Kenmore Kitchen Ranges
I have a Kenmore Ceran electric slide in range, model # 629.46799895 ...it was on, started beeping, and showing fault code F1 on the screen
Sorry to read about your problem.
Try this to determine which part is needed.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
I tried to help you.Please help ma and rate/vote this responce. Thanks and good luck
Jan 04, 2011 | Kenmore Kitchen Ranges
My husband just installed a kenmore single in wall oven and it is screaming F1 at us what does that mean?
Nov 06, 2010 | Kenmore Ovens
My range is beeping f1 where the time should be
HI. This will be a control fault. Possible touch pad issues detected. Use the procedure below to isolate the problem.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so double check before continuing.
Jan 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Maytag Advanced Cooking System Model #MGR5745ADA that is showing a code "F1" on the display. The oven doesn't work.
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Nov 25, 2009 | Maytag MGR5750 Gas Kitchen Range
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore flat top range, Digital clock, all controls on front. C880.4450229B1 ? the controller module buzzes, no display lights up. Cook top controls are fine. Robertshaw 1063-08 module. The buzz is coming...
Try SearsPartsDirect.com or eReplacementparts.com. You can enter your range model number and should be able to locate the controller. However this could be one of the more expensive components.
Oct 06, 2017 | Kenmore Kitchen Ranges
Kenmore electric Range model 635040L0
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Sep 24, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Whirlpool 30" Free Standing Electric Range WFE361LVD Logo
464 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
