Question about Microsoft Streets & Trips 2009 Full Version for PC
Error message: your registry settings for this application were not copied correctly
    Master:
  • 525 Answers
Uninstall and reinstall the program.
Posted on Mar 22, 2011
Get the following error message: Your registry
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Oct 15, 2013 | Microsoft Streets and Trips 2013 B17-00563
Hp pavilion a1102n winxp home. Blue screen after win splash logo, flashes too fast to read. 2x256mb. Dial up modem. Tried: removing modem, removing front usb FireWire media card slots. Removing one or...
Dear,
I saw your video and check the blue screen error. It comes for a friction of second and disappears but i kept my media player in slow motion mode and checked it. This error belongs to a missing registry file.
PERFORM THIS PROCEDURE for recovery.
A Stop 0xc0000218 error message means that a necessary registry hive file could not be loaded. This error message can occur if the file is corrupt or missing. To resolve this issue, you can reinstall the operating system and restore the registry files from a backup. The registry files may have been corrupted because of hard disk corruption or some other hardware problem.
This error message can also occur if the driver has corrupted the registry data while loading into memory, or the memory where the registry is loading has a parity error. In the latter case, turn off the external cache and check the memory chips.
To resolve this issue, follow these steps:
  1. Start your computer by running the Recovery Console, run the chkdsk /p command on the drive, and then restart your computer. Test to determine whether the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to step 2.
  2. When Windows loads, press SPACE BAR when the "Load Last Known Good" message appears.
  3. Complete a parallel installation, and restore the registry files from a tape backup. To do so:
    • Reinstall Windows in a separate folder.
    • Restore the damaged registry hive from backup. This procedure is specific to the backup application that you used to make a backup. Consult the documentation of your backup application or consult the vendor if you need assistance. Typically, this procedure requires you to restore a system state backup to an alternate location, and then copy the appropriate registry files to the %SYSTEMROOT%\System32\config folder of the damaged operating system.
    • If you do not have a tape backup, include the backup of network servers and production workstations.
    NOTE: If Windows is stored on a FAT partition, you can restore the files by using another computer and by copying the registry hive files to the %SYSTEMROOT%\System32\Config subfolder.
best of luck!
Mar 07, 2012 | HP Computers & Internet
I was restoring my computer using Window 7 and get a error message and now I am stuck Can you help me slui.exe application error unable to start correctly (oxoooo7b)
Many users who experience slui exe errors are in the dark about how to fix these types of problems. Fortunately for all of us, the bulk of them can easily be pinpointed and fixed, even if you have very basic technical skills. In the next few paragraphs, I would like to show you how you can effectively do away with these troublesome computer problems.
go trough this link and repair you pc
http://www.topregistrysolutions.com/exe?cd=EXl1792
Sep 02, 2010 | Gateway GT5028 PC Desktop
Error 8e5e0158
1. Open up hidden folder
C:\Documents and Settings\UserName\Local Settings\Application Data\Microsoft\Windows Live Contacts
2. delete anything inside.
3. restart live messenger.
use registry cleaner (reginout) to fix up registry
Aug 15, 2010 | Microsoft Windows Live Messanger
I am using Vista Premier. My Streets & Trips
uninstall. type regedit in run. In the left pane click HKEY Local Machine. Find Software and Click. Find Streets & Trips Delete it 'All". close the box. clean your drive. Restart & reinstall
Jul 30, 2010 | Microsoft Streets & Trips 2009 Full...
Error reading event file
The EVT files include the event log messages as they are stored by the system. Each message is composed of an ID (that is, the message itself) and a number of insertion strings. The IDs are translated into strings through the use of messages DLLs.
All the application event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ Application
All the system event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System
For example, the TCP/IP service's message DLL is defined under the following registry entry:
Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\TcpIp Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ netevent.d
Therefore, all the TCP/IP event log messages are defined in the DLL netevent.dll.
When the user double-clicks an event for which the message DLL is not defined in the registry, the message string cannot be displayed and the following message is displayed: The description for Event ID (51) in Source (aservice) could not be found. It contains the following insertion string(s): ... Below is a description of a way to read the system event logs of a computer with WINS on a computer without WINS. This sample can be adapted for any application or system component.
WARNING: Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to reinstall Windows NT to correct them. Microsoft cannot guarantee that any problems resulting from the use of Registry Editor can be solved. Use this tool at your own risk.
The following operations are required:
  1. On the computer with WINS, run REGEDIT and select the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\Wi
  2. On the Registry menu, click Export Registry File and select a file name (for example, Winsreg.reg).
  3. On the computer without WINS (for example, the one used to read the system event logs of the computer with WINS), run REGEDIT. On the Registry menu, click Import Registry File and select the file Winsreg.reg previously saved on the other computer.
  4. You should now have the following registry entry on the target computer (that is, the one without WINS):
    Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ EventLog\System\Wins Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ winsevnt.d
    You now need to copy the file defined in the EventMessageFile registry value in your System32 directory. If X: is mapped to \\wins_server\admins$, you can run the following command: copy x:\System32\winsevnt.dll %SystemRoot%\System32\winsevnt.dll
    Of course, the file may be copied somewhere else, but in this case you need to edit the EventMessageFile registry value manually so that it points to the directory with the DLL.
  5. Close all the instances of the Event Viewer and rerun the Event Viewer. You should now be able to dump all the WINS events.
Nov 14, 2009 | Cosmi Print Perfect Platinum
Microsoft streets and trips 2009 registry issues on vaio p588e/r
Hi, go to the "streets.exe" file in the program folder, right-click it and go to "Properties". Click the "Compatiblity" tab and uncheck "Run this program...". Try it now. It's what I had to do.
May 03, 2009 | Microsoft Streets & Trips 2009 Full...
Sir i have downloaded a game from net i installed it and tried to open but it gives a message "this application was faiiled to start because mss32.dll file is missing" plse help me to start the game
Mss32.dll Error is a common Windows error message. Mss32.dll Error is usually caused by a missing system files, wrong system settings or a corrupted registry file. Use CTRL+ALT+DEL to get the task manager, if there is anything listed with [Not Responding] end task it. Next, run a registry scan to check for registry errors & other system problems. 96% of the time this will fix the cause of the error
It is best to clean your registry in order to optimize system performance & Fix the cause of many Windows Errors.
Apr 14, 2009 | Computers & Internet
Your registry settings for this application was not
Hi
My personal openion is , by using just only Registry cleaners will not solve your problem
We need to get rid of every supported file.
so suggest you for
1) Uninstall the application
2) Restart
3) Use Regsitry Cleaners
4) After successfull cleanup of regsitry go into registry for manual removal by clicking Start -> Run --> Regedit
5) Now locate HKEY_LOCAL_USER -> Software ->
Here locate the application matches with the name of MS Streets (actually i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE that key
6) Same is for HKEY_Current_User--> Software
7) Now go into System Drive (usually C drive) and locate the programfiles -> MS Streets
(again i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE It.
8) Now restart the system
9) Now we need to use some JUNK FILE CLEANERS for get rid of other supported files
so i suggest you to go with Tune-Up Utilities 2008 version (its trial ware for 30 Day - Fully Functional)
so from that use your JUNK FILE CLEANER
10) After successfull clean up i incist you to execute the Defragmentation process on system drive (usually C drive) so that we can close the backdoor for support files.
11) So after doing all above MAINTANANCE then try to install the application once again
If problem persists.
Please let me know, then I personally get involved with this topic
Thanks
Sep 17, 2008 | Microsoft Streets and Trips 2008 for PC
Microsoft Streets & Trips 2009 Full Version for PC  Logo
123 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
