LG WM14316FD Washing Machine - child lock is on and no other buttons work. Turned power off and on also drained system and didnt change any thing?
SOURCE: how do you remove the child lock off the washing machine
hold the child lock button down for a few seconds.
Posted on May 09, 2008
SOURCE: My Bosch washing machine (WFX145SGB
Eventually discovered that if the 'start' button is held down for a few seconds it unlocks the 'child lock'.
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 112 Answers
SOURCE: LG "WM12336FD" washing machine is displaying ,CL,
I cannot find that model number in any of my LG data.
There is a button on the control panel that will say Child Lock. That button will have to pushed and held down until you hear the chime.
Posted on May 03, 2010
  • 662 Answers
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
LG WD1070qdp inverter direct driver washing machine, will power up but won’t start cycle, (play/pause button not working), cleaned filter, drained it and checked the water input, child lock not in, have...
On some models if you hold in the spin and temp buttons together at the same time and while holding in, you depress the power button then the machine will go into test mode. Each subsequent push of the start button will go to the next test item, ie, spin, water fill, drain, etc. Might give it a try. Good luck.
May 09, 2018 | LG Washing Machines
How to turn off child lock on WTG7532W lg washing machine
Try pressing and holding the Rinse button (between the Wash and Spin buttons) for 3+ seconds. This should toggle the Child Lock off and the Start button should work to resume the cycle. (If you have touched the Power button, you may need to turn on the washer first. The Child Lock feature remains in the last used state.) See page 27 of the Owner's Manual for information on the feature. The manual is available from the manufacturer's support page: http://www.lg.com/au/support/support-product/lg-WTG7532W#manuals . The current link to the manual is http://www.lg.com/au/lgecs.downloadFile.ldwf?DOC_ID=20150102039896&what=MANUAL&fromSystem=LG.COM&fileId=SVYMjStXlkiH8PNt0qdVA&ORIGINAL_NAME_b1_a1=MFL67568754-Eng.pdf .
If you can't get the Rinse button to respond, you may have a problem with the touch pad circuit board, the wiring between the touch pad and the control board or the main control board.
I hope this helps.
Apr 08, 2017 | LG Washing Machines
LG Tromm washer, what does error code ''CL'' mean?
Hello there and welcome to fixya
THE cl is not a error code at all
it SIMPLY MEANS THAT THE CHILD LOCK FEATURE HAS BEEN ACTIVATED
not to dismiss the feature simply press and hold the wash and rinse buttons for a minimum of 5 seconds and release Your machine may be different so you may have to press a different series of buttons like if theree are 2 buttons with the unlock or lock picture on them or shows a child or something like this but it should be 2 buttons that are neded to unlock ok
Hope this is very helpful
Best regards Mike
Dec 15, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-10160 TP. Display is showing code CL and no buttons work. I think it may be child lock but can't turn it off. The problem occurred when I turned off the machine & disconnected the water...
You are quite right, the Child Lock is engaged.
3 options for you depending on the machine:
Find the two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that should reset it.
Or
It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Or
If it has a program selector twist dial, set the selector to off or the end of a program (If it doesn't have, don't worry) Then, unplug from the mains. Leave for 20 minutes without tampering.
Power back on and the machine should have reset
Jul 01, 2011 | LG Washing Machines
Hi, the machine seems to have hung. there is a CL symbol in the timer slot and no button is functioning including the power button. i had to switch the machine off from the mains.
hi.
i am fairly sure that CL in the timer window means that the child lock has been turned on.
this locks all buttons to ensure that children cannot accidentally start the machine or change settings.
to turn it on or off, press and hold the prewash button for three seconds.
hope this works.
if not, please feel free to ask for more details
Mar 31, 2011 | LG WM-2277HW Front Load Washer
Machine displyas CL. Why
It means the Child Lock feature which locks the controls is turned on. Look for the two console buttons, usually adjacent, with the lock and child symbols between them like the one shown below. Press and hold those buttons simultaneously until the CL light turns off to unlock the controls.
Mar 02, 2011 | LG WD-1045FH Front Load Washer
LG washing machine
the CL meant child lock so you have to push pre wash and rinse buttons together to relase the child lock
Sep 08, 2008 | LG Washing Machines
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Apr 09, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
