1996 jcb 526 no lights on dash or gauges working still starts but think battery is not being charged checked fuses they all seem ok
leetamara
  • 702 Answers
SOURCE: The gauges have stopped working ? Fuse under dash seems to be OK ?
Behind the dash is what they call a constant voltage regulator. It controls the guages. It's small and located behind the dash near speedo.
Posted on Jun 19, 2008
jigsawbill
  • 398 Answers
SOURCE: Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
Posted on Aug 06, 2008
SOURCE: 97 Jeep Wrangler Dash Gauges Arent Operating..everything else ok!
check fuse #17 in fuse box under hood. It's a 10 red fuse. that's how i fixed my problem.
Posted on Jan 07, 2009
SOURCE: gauge lights not working.
Solved the problem -on of the fuses in the relay box under the hood was bad - Although it is not marked well - It says park and horn????
Posted on Feb 10, 2009
BlackOnyx
  • 102 Answers
SOURCE: nissan terrano 1996 td27 charging issue.
Did you hear the one about the Terrano with a charging problem?
Just fix it by replacing the thermostat!
Seriously - check your temperature gauge does it take ages for the needle to barely get off cold? (and is the heater useless?)
The needle should get to just below half way in 2 or 3 minutes.
If the thermostat is stuck open, then the engine does not get up to temperature.
The glow plug control senses the engine temperature is cold, so the glow plugs stay on for an extended period of time (sometimes 10 to 15 minutes) - short trips particularly in winter, with more headlight driving - the alternator can't keep up with the current being drawn off and from time to time you will end up with a flat battery!
A thermostat is cheap, and easy to replace (three bolts and about a half litre of coolant - I pumped the coolant from the top of the radiator, and didn't spill a drop when the thermostat housing was removed).
Sure enough, as the engine temperature reached about 50C, the glow plugs turned off.
Posted on Jul 21, 2009
Cavaleir dashboard lights
I would check the key switch first to make sure all circuits have power with the key on.
There is a fuse for the cluster too.
Sep 04, 2012 | 1997 Chevrolet Cavalier
Suburban 1996 4x4 2500 7.4 litter my check gauge light comes on after about 1-5 minutes of driving. the check indicator also pops up on the computer dash at same time . the batter voltage meter goes...
SOUND LIKE ALTERNATOR NOT CHARGING BATTERY,WITH ENGINE RUNNING CHECK BATTERY VOLTS AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS.IF NOT ALTERNATOR NOT WORKING CHECK ALTERNATOR BATTERY POWER FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE AND LOOSE CONNECTION. CHECK ALTERNATOR FUSE.BEFORE REMOVING ALTERNATOR.TURN OFF RADIO FIRST BEFORE REMOVING THE NEGATIVE BATTERY TO KEEP FROM LOCKING OUT RADIO.
Jul 17, 2011 | 1996 GMC Suburban
Hello ,i have a 1996 ford louiville truck, it has a detroit series 60 DD3 12.7l engine, i start engine and is all ok , ten minutes or so the orange warning light on dash comes one and stays on , all seems...
It looks like the altenator is overcharging. Take it in to an autoelectrician and have it checked out on their bench. 15 amps is a bit high for a charging rate, 14 amps is just about the limit.
Jan 16, 2011 | Ford Aerostar Cars & Trucks
Gauges don't work, battery goes dead, ignition changed, battery changed, alternator changed problems presists
Charge battery, start engine, then touch the small terminal on the altenator momentarily with a jumper lead from the hot terminal on the alt. Charge light should go out and batery should be getting a charge. why it does that i still can't figure it out, but it works!
Nov 24, 2010 | Jcb Bruder JCB Loader Backhoe
2004 jeep grand cherokee will not start, dash light blink , gauges move back and forth. Battery seem to be ok.
It takes very little voltage and amperage to operate dash gauges. You cannot rely on "seems" when it comes to the battery. A good battery should have standing voltage of at least 12v and be able to "snap back" from a fifteen second 200 amp load. Under load, the voltage should not drop lower than 9.5 volts. Have the battery charged and load tested before going anywhere else with this. then make sure connections are clean and tight. After you get it started, if battery was good, check starter draw and charging system operation. If it does not start, check power flow from key through neutral safety switch and starter relay to starter.
Sep 06, 2009 | 2004 Jeep Grand Cherokee
Instrument panel went dead
Checked Every fuse in the fuse box (no small task).This includes #4 - Power point Instrument Panel, #14 - Day time running lamps (auto lamps doesn't work nor does auto lock), #27 - ignition switch run feed, #35 - Instrument Cluster, #41 - Instrument Cluster, #42 - Delayed Accessory, #45 - Ignition switch run/start feed, #102 - Door locks body security module, #103 - Ignition switch, #110 - Ignition switch, & #116 - Ignition switch. But I also check all other ones as well, they all register OK. AC panel & radio work. Turn signals work. Mileage does not work, trip computer does. So, basically, everything works except auto head-lights, auto locks, and the dash cluster (no MPH, RPM, mileage display, Fuel, Temp, Tran Temp, and Oil Pressure).
Aug 19, 2009 | 2003 Ford Excursion
1996 BMW 328 IC Convertible Altenator ok but not charging battery
Sounds like the alternator may be missing an excitation current source.
Check the 'IGN' dash indicator lights when you turn ignition switch on prior to starting motor,
if not one of the below may be problem:-
1) check exiter control wire is connected to alternator D+ terminal (low current wire, +V with Ign on),
2) replace dash 'IGN' indicator lamp.
Jul 10, 2009 | BMW 328 Cars & Trucks
Not charging enough to keep battery charged and no dash gauges
The battery charger circuit has failed. If it has a fuse, see if its OK. This input comes from the dynamo, but if your headlights work, then the dynamo is OK. If you are not familiar with the electrical system like checking the leads with a multimeter then best to have a technician(vehicle electrical technician) to check it and if the fuse is OK then the rectifier may require replacement................sodeep
May 09, 2009 | Ford F-150 Cars & Trucks
No electrical power to engine
check you fuses and clean your battery terminals, you might have a relay that controls you ignition. or could be your coil pack.
Dec 03, 2008 | 1996 Volkswagen GTI
Half the elctrics don't work since jump starting the car.
Sent you two .pdfs this morning; they should help you out. Thanks for choosing FixYa!
Nov 22, 2008 | 1996 Toyota RAV4
Computers & Internet Logo
83 people viewed this question
Alun Cox
David Payne
David Payne
