Question about Arris DSR922
AFTER CONVERTING MY DSR922 TO THE NEW SAC OF COMCAST ON X4 I HAVE HAD PROBLEMS GETTING SOME HORIZONTAL DIGITAL CHANNELS SUCH AS 202,206 ETC. VERTICAL CHANNELS SEEM TO BE FINE. QUALITY LEVEL IS STILL ONLY AROUND 55-60 AND IS STRONGER ON C4 581 WHICH IS DIGITAL. HORIZONTAL CHANNELS WORK FINE ON ANALOG CHANNELS ON C3 OR C4 AND CLASSIC ARTS CHANNEL ON GB WHICH IS ANAOLG HAS A SIG LEVEL OF 85. I REPLACED THE LNB WITH A NORSAT 8515 AND APPEARS TO BE A LOT MORE STABLE. RECHECKED DISH ALIGNMENT AND FEEDHORN. COULD I HAVE A PROBLEM WITH THE DESCRAMBLER ON THE DIGITAL SIDE OF THE RECEIVER ? THANKS FOR YOUR TIME. ANY SUGGESTIONS?
I had comcast before but now i don't ,don't use a converter box and somehow I was getting cinemax and other channes on the tv,now i am not I auto programmmed the tv again and mess the the channels...
> I had comcast before but now i don't, don't use a converter box and somehow I was getting cinemax and other channels on the tv
Comcast was providing Cinemax and many other channels as part of your paid services and you will not receive these unless you are a subscriber. There is a good selection of free broadcast channels unless you live outside city areas. If you do, you will then need an external antenna and probably an amplifier to get more distant signals. Auto programming will not find the channels you were receiving from Comcast so there will be only accidental channel duplication; for example, if your former channel 10 was NBC, it may be channel 7 when receiving signal from an antenna.
There are essentially no more 'Analog' stations still broadcasting, they are now all 'Digital.' The abbreviations 'Std' refers to the aspect ratio (H/W) of the picture area and 'Hrc' and 'Irc' the available resolution or how many pixels and lines on the screen.
Aug 28, 2011 | Samsung LE40R74BDX 40 in. LCD Television
I finally subscribed to Comcast's Digital package a year ago, which required the TV that I wanted to purchase on-demand to have a converter box. At the time all of the other tv's still received most of the...
Hello!
Comcast here. Most likely, the channels you need have been converted to a digital signal and now require a DTA (Digital Transport Adapter). Comcast is supplying our customer that lost programing as a result of the digitial transition up to 2 DTA's per home free of charge. Email our team at the address below. We'll get you cared for.
Kind Regards,
Melissa Mendoza
Comcast Customer Connect
National Customer Operations
We_Can_Help@comcast.com
@ComcastMelissa
Dec 31, 2009 | Arris DCT6200 DTV Receiver
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
I'm able to view all local channel in digital (new tv with in philip hdtv indoor antena) but after conver to diggital I lost channel 7 and 9 I scan many time but sitll no lick
What local area are you in? 7 & 9 may have moved to another channel. Every distributor of channels ie. Comcast, Directtv, Dish, Bright House, etc has channels all over the map!! with no real clear plan it seems! If you go to DTV answers.com you can get the new local lineup for your area. At this point, if you still don't have the signal, you may need to re-align your antenna for the best possible reception. If you go to Terk.com you can type in your zipcode and it will show you where the transmitting antennas are located. You may need a better antenna like a Wineguard or larger Terk to get all your channels. Hope this helps
Jun 23, 2009 | Insignia Digital-to-Analog Converter for...
MY DSR922 RECEIVER WILL NOT ALLOW ME TO HAVE THE CORRECT HORIZONT
we live in the midwest and our manual stated we should use linear west setting. well we changed that setting to linear east and the skews are now correct. we actually live in Illinois. thanks for your reply
have a nice day
Jun 22, 2009 | Arris DSR922
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
How to load w5 satellite manually in my 4d-922 receiver
Lost W5 & X4 on myDSR922 how can i get them back?
Apr 08, 2009 | Arris DSR922
PVS31170Si Trutech TV Is this digital?
I have this model. I believe it is digital because the auto channel select finds numerous (a few hundred) cable channels (I have Comcast cable in Houston, TX) at channel 69 and above, e.g., 77-324, etc. I believe that analog tuners won't do this.
Does anyone have a manual for this TV? I'll pay to have a copy made.
Jan 15, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
54 people viewed this question
Top Arris Televison & Video Experts
Marvin
Marvin
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
