Question about Dishwashers
I've got a Smeg DI612CA9 D/wahser. When I turn it on it pumps down as normal but won't stop pumpimg down even when the door is opened. If I leave it for +hrs it will allow me to start a wash cycle, but again goes into the same 'loop' at the pumpdown point. Any ideas?
    President:
  • 1,140 Answers
Hello Myles,
Your description suggests water has leaked (and is probably still leaking) into the bottom of the dishwasher under the wash compartment and is tripping the anti-flood protection system. The pump continuing to run even with the door open would confirms that the anti-floop protection has been activated, although the problem could be a fault with the float-switch for this safety feature.
I suspect you have a leak. When you leave the washer for a few hours a certain amount of this water will evaporate. This allows the float to fall deactivating the float-switch so you can start a wash cycle. However, as soon as you start a cycle, more water leaks into the bottom of the washer and the anti-flood protection system trips again.
You really need to have a look under the wash compartment and check for the presence of water there before you do anything else. If there is water in the bottom, pull the washer out and tilt it backwards about 10-15 degrees to allow any water to run out. You should then be able to use the washer again, but if there is a leak, the problem will return fairly quickly, so this really needs to be investigated fully.
If you pull the washer out to remove any water in the base, I'd suggest putting some old towels behind the washer before tilting it, to absorb any water that runs out. I also suggest getting someone to help you tilt the washer as they are heavy and the bottom can slide out when you tilt it.
You should also switch off the dishwasher and the power supply and close the water check valve ot disconnect the water supply hose before attempting this
Hope this helps.
Regards,
BElectric
Posted on Mar 23, 2011
Smeg washing machine reset
I would first go to the manufactures website for a user guide to identify the root of the fault in the problem section or even write to them for advice eric
Dec 22, 2017 | Washing Machines
Smeg di612ca9
Most likely you need new dispenser and you could buy it on line or you could get it from your local service centre as they might be able to order it for you
Dec 09, 2013 | Dishwashers
Dishwasher cavitates. I have a Smeg DI612CA9
Does the drain hose loop up to the top of the unit before going to the sink drain? If it goes down first it may be siphoning or draining by gravity.
Aug 08, 2013 | Smeg Dishwashers
Smeg washer SLB 6 the door won,t open after program cycle
the machine has a blockage in the filter or pump try putting it on a spin again if that dont work pull the machine out tilt it back wait 5 secs and open the door if you have water in the drum you will know the filter is blocked or pump or if its waist is plumb into the sink waist take outlethose off and unblock hope thats helped you let me know
Nov 06, 2011 | Washing Machines
Smeg fridge smell
Turn it on, or open it up. Even new fridges smell funny when closed. It all goes away when cold. Then open a box of baking soda and leave it inside the fridge.
This assumes the unit is CLEAN.
Oct 26, 2011 | Smeg FAB28NE6 Refrigerator With Ice Box
SMEG SA 425 x Dishwasher - washing spinners stopped!
Can you hear the wash pump operating during the cycle? Pump could be faulty or blocked, or the pcb could be at fault
Jan 06, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
