Question about Wmf/Usa 2.5qt Stainless Steel Perfect Plus Pressure Cooker
No.1 part, the round whistle in the middle of the lid doesn't pop up when the cooker is on and pressure is building up instead the steam comes out of small pressure ball and it sprays everywhere.
    New Friend:
  • 190 Answers
Here are detailed instructions on how to use it. It sounds like the slide on the handle was not set to the locking position:
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Posted on Jan 20, 2014
erickg
  • 116 Answers
SOURCE: slow cooker is lifting its lid during the cooking process
its normal try a towel or a tray
Posted on Apr 15, 2009
SOURCE: Need a steam vent for an Aroma ARC-838TC 8-Cup Rice Cooker
I just called their customer service (used the number on their website) for the same problem, and they are sending a replacement out in a week!! Awesome customer service!!
Posted on Aug 07, 2009
SOURCE: how to clean Zojirushi NS-MYC 18 rice cooker
I just took my lid apart on my rice cooker. My suggestion for dealing with the dirty stainless steel cover under the vent hole is to not look at it! The lid is not designed to come apart. I had to pry the top cover off of the lid. Once again just don't look in the vent hole and everything will be fine. (sorry about the bold letters my bold got stuck.) Have fun with the yuck in the vent hole.
Posted on Dec 03, 2009
  • 1214 Answers
SOURCE: I am simply trying to replace the lid of my rival
As much as I hate to say it, these things are built so cheaply that they are meant to be "throw-away" when something goes wrong with them. I checked the Rival website, and they don't show anything as a replacment item for these crock pots.
It so happens I have the same issue with a rice cooker. Wife dropped the lid shortly after we received the cooker as a gift. We use a plate to cover it now.
Posted on Dec 10, 2009
Testimonial: "I found a metal lid from one of my pots that fit wonderfully. Thanks"
  • 5 Answers
SOURCE: Does steam tray/lid go on top or bottom of rice cooker?
The steam tray as you call it goes on the inside bottom of the cooker. It's purpose is to keep the cooking rice separated from the heating element during the steaming process. The basic measurement is 2 parts water to 1 part rice. Add a quarter cup more water for brown rice. The automatic shut-off won't turn off until the water is gone. It's magic! Cleaning; soak the cook pot and perforated plate to remove rice goo DO NOT USE STEEL WOOL PADS or abrasive cleanser. I use a nylon dish cleaning brush to remove the stuck on brown material.
Posted on Aug 09, 2010
Crofter pressure cooker operating instruction
we have a pressure cooker and you put about a 1/2 inch of water in the bottom, make sure the rack is in bottom under food. then put lid on tight and make sure the seal around the inside of the lid is still soft and movable this means it will seal properly and not leak out the hot air. once the steam starts to build up when it has been on the burner for a couple of minutes, steam should be coming out the center of the lid and there is a little valve that has a pin in the middle of it that will lift up when the pressure is high enough to cook the food, some times I have to tap it with a fork, once the little pin is sticking up by its self put the pressure cap on, ours has a little black stick in the middle that rises as the pressure builds and with practice I know that when I can see 2 rings on the black center then the potatoes are cooked. they can be a very great time safer but dangerous if not used correctly. once the desired amount of rings have raised turn off the heat. NOW DO NOT OPEN until the little silver pin lays flat in the lid again then you know the pressure has reduced enough to safely open the cooker. always open away for your face as it will still be very hot. hope this helps.
Nov 28, 2017 | Home
When I set the manual pressure cooker time, after the pressure builds up, instead of showing PO 06, it flashes end & goes into the warm cycle
If your pressure cooker is going into keep-warm, and you're certain that it's not pressure cooking (ie- the lid is not locked) then the recipe you're using in it does not contain enough liquid. Take a look at the pressure cooker trouble-shooter to see if any of these issues apply to you:
http://www.hippressurecooking.com/infographic-the-pressure-cooker-trouble-shooter/
Mar 08, 2016 | Cook's Essentials As Is" 6qt. Digital...
Cooks Essential Pressure Cooker will not powerup
CooksEssentials 6 qt. Round Digital Stainless Steel ...
www.qvc.com/CooksEssentials-6-qt.-Round-Digital-Stainless-Steel-...
QVCDescription About Cook's Essentials Delivery Date Estimate ... Includes 1000W six-quart pressure cooker, glass lid, and recipe booklet with 40 recipes; Stainless steel ...The recipe was well received and I will cook it again. ... of hissing coming out was notright as it wasn't able to build enough pressure to start cooking.
Oct 15, 2015 | Coffee Makers & Espresso Machines
Cuckoo crp-hd1054f , steam comes out from sides when cooking
Mine was the same after I got it for 3 years the top lid round rubber was degraded. I guess you need to replace the rubers or the whole top lid. The part might be available from cuckoo customer service.
Mar 17, 2013 | Cuckoo Rice Cooker Cr-0631f
Why is there steam pouring out of my pressure cooker when I start to cook a piece of meat? Is that a sign that something is wrong?
Don't worry - it's a sign that your pressure cooker is doing what it's supposed to do. When you first start cooking the pressure is too low to activate the red center which is the overpressure valve. The steam coming out is just a way of getting rid of any cold air that's inside the pressure cooker. If the steam continues to escape later on in the cooking process then you need to check that your overpressure valve is clean and that the red center button is in the correct place.
Feb 14, 2013 | Home
Pressure cooker not building up pressure
Shanihulugal- please contact us at 1800-207-0806 x 127 or at: info@fagoramerica.com
We will replace the pressure cooker pot if the unit is defective.
Thank you.
May 31, 2012 | Fagor Duo Pressure Cooker 4qt
Still very new Tedelex pressure cooker: the red-headed pop-up valve seems to take for ever before "popping" and allowing steam pressure to build up. How long should I wait? Thanks, Nic
My pressure cooker does that too, you would have to wait until the steam starts to come out a lot, then it will pop out and start building up pressure. Hope this helps.
Apr 08, 2011 | Crock Pots & Slow Cookers
How do i use the pressure cooker? After adding water and beans, I let it come to boil and the steam noise is steady....then I turn down the heat? At the end I let out the steam manually, turn off and open...
Add the water and beans. Put the lid on the cooker and tighten down. Turn on the heat and let the steam make a full plume before closing the valve. Lower the temperature to medium. Watch the gauge and when it reaches the correct pressure keep adjusting the heat to maintain the pressure for however many minutes the beans need to cook. When the time is up turn off the heat and let the cooker cool for a while. Ten minutes or so. Then slowly open the pressure valve when the pressure has reduced to a low level. If the pressure is still to high when you open the valve the water will be pulled out of the beans and the jars will only be half full of liquid. Once the pressure is down to zero, open the lid carefully because the jars are still hot and break easily. As the jars cool you will hear them pop. This means that they are sealed. Good luck.
Jun 15, 2009 | Kitchen Appliances - Others
Wolfgang Puck Bistro 5 qt Pressure Cooker. How to steam?
Throw away this "Made in China" piece of **** and buy American. That's what I had to do.
Jan 05, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Wmf/Usa 2.5qt Stainless Steel Perfect Plus Pressure Cooker Logo
211 people viewed this question
Top WMF Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a WMF Kitchen Appliances - Other Expert? Answer questions, earn points and help others
