SOURCE: Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
SOURCE: need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
