Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Reset oil change diplay after oil change. yth20k46
    New Friend:
    Problem Solver:
  • 14 Answers
How to add and change oil in transaxle on husqvarna yth20k46
IIRC,these are sealed units,you don't need to change the oil !
Aug 15, 2014 | Husqvarna Garden
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
Connected a battery wrong and now Husqvarna YTH20K46 will not crank
look for a blown fuse there taped to the harness
Jun 02, 2012 | Husqvarna Garden
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
After servicing my acura TL 2005. I still get diplay that "servicing due time passed" is that a fault?.
You need to reset your service reminder.
  1. Turn the ignition switch to the ON (II) position.
  2. Press the INFO button (button with arrow icons) repeatedly until the engine oil life is displayed.
  3. Press and hold the SEL/RESET button for 10 seconds. The multi-information display will ask for a confirmation.
If you are sure you want to reset the display, press the SEL/ RESET button to select "OK".
Dec 19, 2010 | 2005 Acura TL
Husqvarna yth20k46 - When turning transmission does not work
I only had my mower 3 months and that problem started. I was told to change the drive belt, It got worse. Now the transmission will only drive the mower for about 15 min and will come to a complete stop. I have to let it sit about 30 min before the drive will work again. No solution yet but I'm looking at replacing the "sealed" drive assy. I do have a very healthy yard of St Augustine which is tough. I can mow a thinner yard a little longer.n
Apr 06, 2010 | Husqvarna Garden
Change engine oil message stays on
the Change Engine Oil message is diplayed in the driver information center when the oil change is due ,,,,, to RESET display message , press the INFO button to display the ENGINE OIL LIFE message , ,, Press and Hold the RESET button untill 100% ENGINE OIL LIFE is displayed.
Dec 23, 2008 | 2001 Cadillac DeVille
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
224 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
