Question about Sony KDS-R60XBR1 60" Projection HDTV
My tv turning green all of sudden Is there a way to reset it back to it orginal colors
  • 10,594 Answers
If tv is Sony KDS-R60XBR1 as shown in question headings then it is problem of optic block (light engine) that needs to be replaced, it is hardware problem that wont get solved by resetting. Optic block is expensive part and qualified tv tech is required to replace it.
If tv model number is different, please post it to provide you info about problem.
Thanks.
Posted on Mar 22, 2011
Why did my Kolin DLT-3212M LCD tv picture suddenly go green
Are you connected with a box of some kind via the component input on this set? (red, green, blue connections?
If so unplug that box and wait--plug it back to see if the box will reboot and correct the issue--also you can try to swap green cable itself with blue for example and if then have BLUE issue that cable is bad.
May 20, 2012 | Televison & Video
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
I have LG PLASMA 50" TV. Suddenly It's stop working. NO AUDIO NO VIDEO. TV On/Off light changes its color from RED to Green but no video Audio. Is someone can help me?
Tries to reset the tv and the cable box.By unplug the tv and cable box about an hour later.Plug both devices back in.The tv now reset it self,tv boards are resetting back to factory setting.The cable box is resetting and it updating it software.The tv now should work.Not,than the tv Tuner board is dead,that the board,where the incomming broscasting signal cable plug into this board in the tv.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 03, 2010 | LG 42LG50 42 in. LCD HDTV
Too much green dont have orginal remote. Is there
your tv needs repair one of the transistors on the neck board is bad..the neck board is connected to the picture tube end inside the tv..but be care full as it stores very high voltage.if you are not a tech have a tech look at it.
Jul 11, 2010 | Zenith Televison & Video
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
I have a Panasonic 37 inch Plasma Viera 37PX50U The color has suddenly turned to all green and purple. Would like to reset factory color settings.
Hi dennisreno,
You should be able to set the tv back to factory default settings from the menu.
I will see if I can find the user manual and give exact directions.
Let me know if you find the reset.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 29, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Akai LCT2701TD Color problem
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Apr 23, 2017 | Akai LCT2701TD Television
Sony KDS-R60XBR1 60" Projection HDTV Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
