Question about GE Monogram ZISS480DRSS Stainless Steel
I have ge mongram 48"
    Guru:
  • 262 Answers
This issue could be because of three different parts in the fresh food side.
Here is a link to your units fresh food side parts diagram.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-ZISS480DRDSS/0432/0165000/G0504179/00007?componentDescription=&brandDescription=&searchTerm=sensor#Partslist
Look at part number 336 temperature sensor....tells the control what the temp is and it adjust the damper door part number 367
so we must determine is it the damper that is getting the signal from the control board but is unable to adjust to the controls command because it is stuck,broken,or the motor is bad.
Or is the control getting the info from the temp sensor but is unable to relay the info to the damper door.
Or the temperature sensor ( also called a thirmister) is not relaying the temperature correctly or not at all to the control board (part number 390)
On this link you will be able to check the thirmisters value off of the mother board that is located on the very back panel of your refrigerator.(the backside that is against your wall.)
It will be the last link on the procedure....called a tech sheet. This is the Mother Board print.
click on the link
GE refrigerator non defrost issue with Mother... This procedure will define the issue with a non defrost issue in all GE refrigerators controlled by
If the Thirmisters check good then you will need to get to the damper door and check to see if you are getting power to it. If you are then the motor is bad ...but first check the door itself for damage or blockage. If the motor/damper is getting power and the mechanics are good on it then you will need to look at the control board.Look for burnt marks ....but if the other parts are good then most proably it is the temperature control board.
Please post results
Posted on Mar 22, 2011
Refrigerator temperature shows 60 degrees but waterline is freezing
yes thermastat maybe bad check sencer for temp it maybe bad
Aug 29, 2014 | Refrigerators
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fine, fridge too cold!
You need a new fridge side Thermistor. If that doesn't solve the problem, then replace the Damper Actuator.
Jan 05, 2018 | Zanussi Z32 / 5 Top Freezer Refrigerator
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
GE Monogram ZISS480DRSS Stainless Steel Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
