Question about Seiko 0512037FA Wrist Watch
How do I reset my seiko digital chronograph wrist watch from military back to standard time?
SOURCE: Seiko Watch band Adjustment
hi. you have to push or hammer the pin out in the direction showen by the arrow, so the arrow is dis-assembly direction.
Posted on May 21, 2008
SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Posted on Jan 12, 2009
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
  • 6 Answers
SOURCE: Seiko Sportura SNJ007 chrograph watch instructions
Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
http://www.seikowatches.com/support/ib/index.html
Posted on Jul 27, 2009
SOURCE: seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Posted on Sep 24, 2009
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 14, 2010 | Watches
I need to ''reset'' a Seiko alarm chronograph watch, purchsed in 1999 to display ''standard'' time, rather than 24-hour, ''military'' time. Any idea how I do this? Unfortunately, my instruction manual has...
You can get instructions from their web site "Seiko.com".
Click on "support" and then on " instruction booklets" and then scroll down the page and you will see
a list of watches.
Download the PDF for your watch.
Apr 23, 2010 | Watches
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Mar 14, 2009 | Seiko 0512037FA Wrist Watch
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
Convert Military Time Setting to Standard
If its the watch I think it is try holding in the top right button on the watch. That should change it back to 12 hour time
Mar 07, 2008 | Watches
Ancient Seiko digital watch
you need to give the movement number. at seiko watches you will find a number which has 8 letters and/or digits devide by -
Mar 05, 2008 | Watches
Seiko 0512037FA Wrist Watch Logo
239 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
