Question about Microwave Ovens
Sound device not available - Microwave Ovens
How to replace a oven light on a inverter microwave
Posted on Mar 26, 2011
My microwave is making this buzzing sound n not heating but all other part is working..can it be fixed?
take it to an appliance repair centre for a proper diagnosis and quote
if parts are available it can be repaired but the cost is the determining factor
Dec 29, 2016 | Microwave Ovens
Panasonic NN-CS598 thermal safety device
Could be, sound more like the oven thermostat is bad-easily fix actually
Aug 24, 2012 | Jenn-Air JMC8127DD Microwave Oven
Fan is barely running. during cook, fan runs weak and vent fan does not run. tech said maybe a control panel? i can do the work but need a parts and service manual. are these available? does the weak...
probably a defective motor or slipping blade. i'm not sure how old your amana is. if it's the real old chrome metal '70's or early '80's vintage models, the part may not be available anymore.. they were very common to fail.
May 16, 2011 | Amana Radarange Microwave Oven
Error code 28
I take it this is not a microwave! If it is can't help.
http://pcsupport.about.com/od/findbyerrormessage/a/code-28-error.htm
Error 28 means the device manager cannot find or has a corrupt driver.
So;
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Mar 11, 2011 | Microwave Ovens
I cannot find my manual. Is there one available online?
go to this web site and you should find your manual for your microwave. kitchen.manualsonline.com/manuals/???device/microwave_oven, have a nice day.
Sep 09, 2010 | Microwave Ovens
Breville BJE200XL - the basket that holds the pulp is cracked, I need another one
I will suggest you check amazon.com or ebay.com to order for the part you needed for your device. The part should be available in any of the site mentioned above.
Take care.
Aug 20, 2010 | Microwave Ovens
Microwave oven push buttons not working no sound not functioning
You have a failing membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10950 and you can get it here for $89.59 (compared to over $135 from from GE!).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Oct 07, 2009 | GE JES738 Microwave Oven
Microwave not heating and countdown lasts 20 seconds before stopping. put food in and start as normally do then it stops. Microwave is the genius 1200w.
It sounds like it is the "magnetron" has given up. In any Microwave there is a device called magnetron. This is the device which radiates microwave to heat up anything inside for set time.
Before the device gives up most of the time usually the microwave makes little bit of loud noise. Usually it happens when there is abnormal power.
Remedy: Any qualified technician should be able to replace it. The spare is available from the service centre of the manufacturer. In most cases spare is expensive and it is better off to buy another one.
Jul 16, 2008 | Microwave Ovens
Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Mar 22, 2008 | Microwave Ovens
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
