Question about Philips DVDR75 DVD Recorder
Need to know how to finalize recorded disc so that it can be played in regular dvd player
    Sergeant:
    Champion:
  • 234 Answers
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Posted on Mar 22, 2011
3 Suggested Answers
  • 6 Answers
SOURCE: no finalizing dvd disc
Did you check to see whether the other player will play that type of disc?
Posted on Dec 10, 2008
  • 5524 Answers
SOURCE: cAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Posted on Jul 09, 2010
Can DVD'S be fixed to play on any dvd player?
,THATS GOOD NEWS. cheers,,. u don't mention what recorder u r using when u put the tdk-R IN,,, DOES IT TELL U TO format the disc ???????? if it does and u don't format it will not record on disc Hi again if u wa?t to use RW rewritable disc's then u don't have to finalize them to play on other DVD players u can buy rw disc's on ON. E/EBAY Cheers.,..,..,...., try another brand of disc like TDK .THEY R GOOD ..when u have recorded a movie go into youre menu and find FINALIZE ..when u have finalized the disc it will play on most dvd players good luck
Oct 19, 2015 | Televison & Video
I am able to copy my vhs to dvd on this device and it will play back on this device but the dvd's will not play on any other player. Can you help with this please?
Not completely sure about the "device" you used to make the recordings, but most likely the reason for them not playing on another player is that whenever you record DVDs, in order for them to be readable by regular players, the DVD must be "finalized". Once that is done, and the device you used to record the DVD should be able to do that, then you should be able to play them on a regular DVD player. Know this, however, that finalizing the disc means that no more data can be recorded to it.
Sep 01, 2015 | Televison & Video
LG DVD recorder RH735T. Page 10 of the manual says to finalize a disc before you can play it on a different unit. But when I record something on a disc, the settings menu will not allow me to finalize
On my Toshiba DVD burners, you need to first open the DVD tray, and while it is open hit the regular menu, then DVD menu, select "FORMAT" from the DVD drop down menu, then "FORMAT MODE", which leads you to the 2 CRITICAL Choices :
1) Video Mode - Which has the DVD recording in "DVD Compatibility Mode" so it is "Compatible" with most other DVD Players
OR...
2) VR Mode- Which says "Editing Possibility mode" (Note you need a "+R DVD "to be able to do editing, at least on my machines.
Obviously you'll close the DVD tray to be ready to record
Finish the DVD, @ "DVD" Menu, & Finalize, or what you need with "VR"
Mar 02, 2014 | LG Televison & Video
MY DVD R DISC WILL NOT PAY IN MY DVD PLAYER - I HAVE A SONY DVD CAMCORDER BUT THE DISC WILL NOT PLAY ON MY DVD PLAYER
Please finalize recorded dvd disc in camcorder then it can be playback in any other dvd player.
Disc finalize option is available in camcorder disc menu.
Thanks.
Sep 09, 2009 | Sony Handycam DCR-DVD403 DVD Camcorder
Dvd recorder can't read disc it previously read
Take the Disc out and put it aside. You must clean the Laser Eye, and clean dust and other matter from inside your recorder. Clean Eye with rubbibg alcohol and q-tip. A regular CD/DVD cleaner disc will not work. After cleaning, reinsert your Disc and Finalize it.
Jan 02, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Dvdr3576h will record on dvd+r but will not play on other devices
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
Nov 14, 2008 | Philips DVDR3576H DVD Recorder
I can't see the dvds into any dvd player
Most DVD players can't play DVD-R or DVD-RW unless it's finalized (if you record to DVD+RW, it may work ok, but fewer DVD players work right with RW format discs).
Obviously, you need to ensure you are actually writing to the DVD (eg, will they play back on the camcorder). You should see if there's a menu for finalizing the DVDs, that might do it. There are occasionally problems with finalizing discs on some of these DVD camcorders... these discs may not be readable on any DVD player, but might still work in a PC.
The other problem is that some camcoders record in DVD-VR format, which is a special "easily edited" format for DVD camcorders only... regular DVD players don't usually support this (well, some new ones might... this is one of those "evolving standard" issues). You'll probably need a PC to read the disc, edit, convert to a conventional DVD, etc. if you're using this format.
Jan 02, 2008 | Samsung SC-DC164 DVD Camcorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
RCA DRC8005N Will not finalize discs
well the problem is that the machine are not closing the dvds, you say you go step by step, but it realy is not closing the disc, it can play the not close dvd, but you cant play in a regular dvd player, I dont think is a cleaner problem, but try any way, blow dry air by the dvd port, and see, if not you got a damage one...god luck
Aug 10, 2006 | RCA DRC8005N DVD Recorder
Philips DVDR75 DVD Recorder Logo
1,603 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
