Question about Whirlpool GU2300XTSS Stainless Steel 24 in Builtin Dishwasher
My whirlpool GU2300XTSS0 dishwasher does not cycle between wash/rinse/dry cycles. It fills, washes, drains and refills in the same cycle. What can I do to solve or check for solutions to this?
  • 55 Answers
This means the software in the control board is corrupt. YOu would need to try a power cycle, if that does not work, replace the control board to fix the issue. You could purchase the control board from the link below. Type your model number in the search box to look at a parts diagram.
The screws around the control panel would need to be removed and the control rotated down. The board clips into position and the ribbon cable simply plugs in. Very easy repair.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
There is still water on the dishes and in the dishwasher after the heated drying cycle. Not a lot but enough to wet the kitchen floor. What can we do?
check the kitchen drain is clear - looks like the drain cycle is not working efficiently.
Also make sure the filters at the base of dishwasher are clear.
Try a short cycle (like rinse only) and see if water drains at the end. If problem is occuring only during the normal wash cycle, then drying fan may be the problem.
Jan 08, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher DU810CW fills for 20 sec.
well the timer and the float are the only two things that control your fill cycle,
so since your float is correct ie the rinse cycle
we can only assume that it would not be intermiten it is just a cherry switch
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=255697&diagram_id=77498#d77498
here is the link to the part (timer)
and the breakdown of how to get at it
Oct 27, 2009 | Dishwashers
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool Quiet Partner 2
    More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
    Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Whirpool 1100TXP Dishwasher.
    is your water temp set at 120 degrees
    Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
    GE Nautilus won't drain after Rinse Cycle
    Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
    Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
    Whirlpool GU2300XTSS Stainless Steel 24 in Builtin Dishwasher Logo
    139 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
