Question about Cameras
My ipod is on disable mode and i can't disable it
  • 52 Answers
If the iPod is in Recovery mode, you can use programs like ZiPhone or iNdependance. If your iPod is in DFU mode, then hold the home button and power button down at the same time to exit DFU mode. If the iPhone is in DFU mode because it was unplugged in the middle of a restore, then you'll have to restore the iPod, which will unfortunately delete everything on it.
Posted on Mar 23, 2011
How to connect a disabled ipod to i tunes
Place the ipod in to recovery mode ( power down and then plug in the USB cable to the computer with iTunes that is connected to the Internet, and then with the end that plugs in to the ipod, 0lug it in while holding the home button down) the ipod should boot up with a image on the display that shows iTunes symbol and a cable needing to be plugged in itunes should recognize that the ipod is in recovery mode, iTunes should say some thing to the affect of ipod has been detected in recovery mode, it needs to be restored before you can use it, ALL INFORMATION WILL BE LOST, no way around it
Jul 10, 2014 | Apple iPod touch
IPod 4 is disabled
Heres what you must do,However, be aware that this process will erase all data on your iPod Touch. To fix the disabled problem, you must go into DFU Mode and restore.
DFU Mode
  1. Connect your iPod to your computer
  2. Turn your iPod Off
  3. Press and hold the power button for 3 Seconds
  4. While continuing to hold the Power button, press the home button as well for 10 seconds
  5. While holding down the home button, release the power button for another 10 seconds
  6. iTunes should detect the iPod in recovery mode, press OK, and restore your iPod, from this point forward you may release the buttons. If you have not reached this point, then you have not entered DFU Mode
Your iPod should be running again after this process. From this point you can restore from a backup, if there is one present.
Mar 22, 2013 | Apple iPod touch
How can I unlock a disabled ipod touch?
Step 1:
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
Feb 10, 2013 | Apple iPod touch
How do i enable a disabled ipod that says disabled connect to iTunes
Connect to iTunes using usb to restore the device.
If this does not work you can try putting it into Recovery Mode and DFU Mode using these instructions.
Mar 05, 2011 | Apple iPod touch
My ipod says disabled try again in 5061441 minutes what should i do
Got to itunes, when the ipod shows up click on the ipod from the devices part and the icon will say restore,evryhting will be erased....if itunes makes you type in the passcode in order to read the ipod,take your ipod to the apple store or at&t.
Mar 23, 2010 | Apple iPod touch
Ipod disabled
You can restore it using itune 8.2.i recommend itunes 8.2 due to have less error while restoring.then jailbreak your ipod if it is still on dfu mode after restoring itunes.
Jul 21, 2009 | Apple iPod touch
My ipod touch is disabled and i cant hook it up to itunes cause it needs a code but its disabled and is stuck at the disabled screen.
you will need to put your touch into recovery mode aka DFU mode.
Here are the steps:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Iphone and itouch dfu mode
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
Jun 16, 2009 | Apple iPod touch
8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
if you need any further help let me know.
Good Luck
Jun 01, 2009 | Apple iPod touch
I know the password but the ipod ttouch is disabled
If you have the password why would it be disabled?
RESTORE in DFU MODE
You will have to put it in DFU mode and restore it in itunes.
May 14, 2009 | Apple iPod touch
Ipod is disabled
Hold sleep and home button for ten secs (or until you see recovery mode screen) then connect to itunes
May 18, 2008 | Apple iPod touch
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
