Question about Whirlpool Washing Machines
My machine started leaking in the front at the bottom of the door and when I took the washing out I noticed the black rubber which surrounds the tub (about 2inches wide ) is loose from the sides and wavy.
  • 822 Answers
You need a new door seal.............easy fix..............
cheers
Posted on Mar 22, 2011
I have a two month old Samsung WF350 front load washer. I have a trickle of water leaking from the bottom of the door during wash cycles.
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
Jun 26, 2010 | Samsung Washing Machines
Whirlpool duet washer leaking from underneath
You will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: You can refer to searspartsdirect.com for some excellent exploded view diagrams of your washer for reference in locating components.
Sep 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
He3t washer leaking corner bottom
Sep 03, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rubber circular tube inside front has hole
just get a new door seal for it.
On line they will not be to expensive
Jun 05, 2008 | Malber WD1000 Front Load Washer/Dryer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
32 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
