Question about Clarion DXZ945MP CD Player
When i hit eject it won't eject it just makes a noise so i opened it up and if i push back on the slider bar it will eject but i have to do this everytime i want to eject a cd
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clarion Master
  • 2,226 Answers
The only way to really repair it, is to replace the cd mechanism. you can get it at pacparts.com.
Posted on Mar 22, 2011
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
My CD is stuck in the CD player. It will play, but it won't eject. When I hit the eject button, it makes noise, but nothing happens.
Sometimes there is a small hole in the front panel, you may push a paperclip straight into the hole and it will eject the tray manually. If there is no hole than the unit has to be removed and opened to gain acsess. The reason for the failure is belt wear. Thank you, Dana
Feb 16, 2010 | 2004 Jeep Grand Cherokee
My ps3 won't take the disc it is like there is a lever in the way what do i do?
did you take the drive apart with a disc in it?
There are 2 little white "bars" that pop up when the disc is inserted most the time this happens when a drive is taken apart with a disc still in it and its not in the ejected state.
if you didnt take it apart then there is prolly a cd in there still and there is a problem ejecting, if you did take it apart here is how to reset everything to the right working state. sorry if its hard to follow.
to get it back to normal you need to reset it, if its under warrenty send it in cause the only way to fix this is by taking apart the ps3 and and the blu ray drive.
ussually this happens when a drive is taken apart with cd in and you remove the loading gears cover(the black piece with the levers and the wheels) off.
when you put this cover back on you need to make sure that the wheels are open all the way --- right wheels up and to the right, ..left wheels up and to the left. When its open like that you can see the gaps where those little white bars fit into just put it back on with it open and the bars in the gaps.
usually your looking at more steps though because the rest of the hinges on the lid wont line up. you can try to put the cover back on and eject and try loading an old or blank cd, blank because if something is off it may scratch it.
see if everything works.
if not you need to re-align everything to be in the ejected state. to do that you have to manually move the long black piece on the left side of the drive(with the cd inserting side facing you) and firmly but carefully push it twards the back of the drive and the laser should lower. it may make a poping noise if you go to far but should be fine its just the piece going to far out and poping off the gear. to test it push the cd guide wheels open and it should raise the laser and you can now lower it using the eject button. if it doesnt and you just hear a spinning gear gently nudge that long black piece on the left that you pulled back earlier towards the center of the drive and it should catch itself. after every thing raises and lowers fine make sure its in the ejected state and put the cover back on. should work now.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
CD stuck in my car CD player and cant eject it when i hit the ej
it may be you have a paper label on the cd most car cd player won,t handel paper lables not enuf room as for getting it out try this get a light and see if you can see the cd if so take a pop sickle stick with a small amount of super glue on tip and be vary careful put the pss in to opening to the edge of cd let set for a few seconds then try pulling it out when pushing eject donot use but vary little super glue i have done this on some cd player
Mar 26, 2009 | Car Audio & Video
My disc is not changing and is stuck ( CHM - S620 by Alpine )
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Feb 16, 2008 | Alpine CHM-S620 6-Disc CD Changer
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
DVD stuck in my Panisonic VCR/DVD Combo
try unplugging the power, plug back in, quickly hit the eject button.  You might be able to get it to eject that way.
Oct 14, 2007 | Televison & Video
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Clarion DXZ945MP CD Player Logo
234 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
