Question about HP Photosmart C5280 Printer
I have an hp c5280. the machine will not turn off and the l panel light continually flash. I tried unplugging all cords and replugging and I still cannot turn it off, lights still flash, and cannot print.
  • 122 Answers
Hello Friend, Please check on the power switch connector it might have pulled out from its place. So gently open it, and check on the switch, you will find a solution from there.
Posted on Mar 22, 2011
Hp p/smart c5280 all lights flashing
Is this your problem:
The power light and about all of the left lights are blinking and there is
nothing on the display screen. Trying to turn off the machine does not work and
results in the same error. "Hard" reboots do not work.
Switch the cords if you have another HP Photosmart printer, even if the
latter one is still working.
I thought of this early but then decided to watse three hours of my life I
will never get back,
Do you have another HP printer with a similar looking power cord?
The cords should go into the back of the printer very easily. I have an HP
C5280 and a newer HP C309 and I just moved. Actually, I have three printers
including an HP 7510. The 7510 and the C309 worked just fine when I set them
up, so I figured they both had to be utilizing the proper cords. But I was
sismaken.
I undid the C309 cord and replugged it and noticed it was hard to put into
that machine, despite that it still printed, just as the one I was using on the
C5280 was difficult to plug in. So I made sure the transformers were basically
the same and switched the cords.
Your first tip that something is awry is if it takes any effort to get the
power cord into the machine in the first place.
Hope this works!
Feb 15, 2011 | HP Photosmart C5280 Printer
How do you set it on english
Follow these steps to resolve the issue.
  1. Unplug the power cord from the back of the product.
  2. Press and hold the OK button and the Help button simultaneously, and reconnect the power cord.
  3. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
  4. If the product automatically turns off, turn it on.
  5. Allow the product to fully start up before continuing with the product setup.
  6. Select the correct language code and region when the product prompts.
Regards
Riztech
Nov 26, 2010 | HP Photosmart C5280 Printer
Screen does not turn on.Standby light flashing continuously
Tries tv reset by unpluging,replug tv back like an hour later.The tv is resetting now,back to the fatory setting.The tv should work now.Not,than the power supply board is having problems and dying.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 08, 2010 | Pioneer PureVision PDP-434HDE 43 in. HDTV...
I have an hp C5280 all-in-one printer, and it is shown as offline how can i fix this?
The fact that the printer says it's offline has nothing to do with whether or not you are online (internet) or offline. It just can't communicate with the printer. Have you tried power cycling the printer and your pc?
Assuming it's USB, have you, by chance, unplugged in and replugged in into a different usb port?
Jun 04, 2010 | HP Photosmart C5280 Printer
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
Scanner 2 error won't allow machine to operate even after turning on/ off numerous times
turned off machine. Unplugged computer connection,disconnected power cord from source. replugged computer line, installed power cord, turned machine back on. worked..... turning on/off at switch did not work.
Sep 30, 2009 | HP Office Equipment & Supplies
Ink System Failure 0xc18a0501
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Sep 24, 2009 | HP Office Equipment & Supplies
Printer trouble
Try following this steps:
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps........
Aug 09, 2008 | Office Equipment & Supplies
00C515C4 error message
Hi, First I unplugged power cord from back of printer for about 60 seconds....then I plugged power cord back in to printer....next I held down the Power button on printer and it seemed to do a Reset of the Printer....All has been well every since.....Good Luck....
Jul 10, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5280 Printer Logo
240 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
