Question about Kenmore Dryers
I have a Kenmore Dryer (110.86180800) and it stops in mid cycle. I see no obstruction and I cleaned it in and out in case it is overheating. Once it stops it will not turn back on right away, Just have to wait a few min. and it makes a click and you can start it again. It will only work for 1-4 min. at a time.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Your motor is overheating and tripping the overload protector. You will need to replace the motor.
Kelly
Posted on Mar 23, 2011
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
I have a Frigidaire affinity dryer all I had was nothing bout problems and is fairlly new. when I set in one of the setting and click option to wrinkel release. the dryer gets hot and it spins but the...
Patricia, we apologize that you have had such challenges with your Frigidaire Affinity Dryer. I would suggest double-checking a few things. First, let's check the lint filter area. Let's ensure that there is no thick lint or lint residue. The next item we need to check is the ducting that leads outside, and outside where the ducting exits, to make sure that nothing is clogged with lint or any other obstructions.
If the air flow is being blocked, this could cause your dryer to take a long time to dry or stop mid-cycle. If this is the case, it could potentially cause overheating, which could cause the dryer to stop mid-cycle as a safety precaution.
If you find that there are no blockages or lint residue, you have additional options: First, ask your repairman to contact the manufacturer while diagnosing your dryer to check and double-check that nothing has been overseen in regards to resolving these issues. Secondly, you are always welcome to contact the manufacturer directly and see what other resolutions may be available to you.
-Best regards -
WP
Apr 07, 2014 | Dryers
Dryer Model #DWXR483EG1WW turns off mid cycle (timed dry) Dryer will restart after 10 min or so but will shut off again shortly. Timer is advancing. Dryer technician suggested replacing timer. Advice?
It sounds like the technician is clueless on this one.
The first thing I would do is to remove the vent hose from the back of the dryer and try to run a cycle. It will heat up the room it's in but you will only need to do this once. If the dryer operates correctly you have a venting problem and need to clean the vent in your wall to make sure there are no obstructions and be careful not to kink the vent hose at all when it is reconnected.
If this does not fix your problem there is a chance that the motor is overheating and needs to be replaced. If you need further help just let me know.
Oct 06, 2010 | GE Dryers
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
E1 comes on during mid cycle and stops the dryer from drying
replace the compressor "compressor relay and the compressor overload" that are on the side of the compressor.
location: should be in the back on the bottom behind the panel.
if you have a circuit board they may need to be replaced as well.
May 09, 2009 | Kenmore Elite HE4 Electric Dryer
Gets warm but not hot enough.
Occaisionally this is due to either dryer being set to a 'delicate' or 'low' setting. Most frequently it's due to an obstruction in airflow so the heating coil is cycling off to prevent overheating. The vent at the back of your dryer should be cleaned out (by sucking out the lint with a vacumn hose) at least once a year. The vent pipe out of your house as well. Make sure that the flap on the outside of your house is opening and allowing free air circulation when the dryer is on. And make sure you clean your lint trap every time you use the dryer.
May 03, 2009 | Dryers
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer stopped in mid cycle.
Sounds like you might need a new motor.
Mar 06, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
